2001 Cavy part out! - North Central Region Forum
Well guys, another one bites the dust.
Im parting out my 2001 Chevy Cavalier, Ecotec swapped, turbocharged, and almost ready to run.
For starters, this is a 2001 Chevy Cavalier Base Coupe 5 speed. No power options, no cruise, and no tilt. It had the LN2, but I pulled it for an Ecotec. The engine is in the car, all it needs is exhaust and either a tune or stock injectors and is a turnkey setup. The car was in an accident a few years ago. A deer rolled down the drivers side, ruining the windshield, front fender, door, and rear quarter. The quarter on the drivers side does need some attention as it was rusting from the inside out. Other than that, the body is in fair shape.  Has 136,000 miles on it, original. The battery was relocated to the trunk via a Jegs relocating kit. And I swapped the rear end to a 2003+ rear bumper only, the tail lights are still 2000+. It has a 2000+ LSS/Z24 front bumper without the lip, but has the driving lights with pigtails for custom wiring and the hardware to mount a lip on it. I also installed a cheap eBay short throw shifter.
The suspension got some work. I started off with an upper front strut tower bar, just a basic Ractive, adjustable, but the shape of the bar wasnt properly shaped, but it did the job. I followed that up with KYB GR2s and Megan Racing lowering springs, which dropped it 1.75. Then when the LN2 came out, I dropped the sub frame down, sent in and the control arms to get the seams welded and shot blasted.  While in the process of powder coating, I ordered poly urethane control are bushing and transmission mount bushings. And it got a ADDCO 1 front sway bar.  The engine mounts are also poly urethane.
I have two engines. The one in the car had 80,000 miles with a busted cam timing chain. I tore the engine down, rebuilt the cylinder head with a 4 angle valve job, new stem seals, replaced any bent valves, new timing and gaskets, and a new piston, ring set, bearing set and ARP head studs.  The other engine got stripped down, cleaned, and thoroughly inspected. The block is STD bore and either needs a hone or a perfect block for Darton Sleeves, and also has ARP main studs. I took it upon myself to finish what GM started with the counterweights and did a full polish and knife edge. This will cut down on oil splash and hopefully will cut down on oil temps. Plus it freed up some rotating weight, it just needs to be balanced. I coated it with Conklin Rust Aside to keep it from rusting up. I picked up a set of Eagle H beam rods from a buddy of mine, but never installed them. The oil holes got chamfered and the journals have been micro polished at STD/STD. I also have Clevite H race rod bearings and GM main bearings, both STD for the crank.  From mild steel, I had a guy make me a set of neutral balance shafts as well.
The turbo setup was a custom deal, starting with a Garrett knockoff hybrid T3/T4 turbo, .74 A/R cold side and .64 A/R hot side. Then I added a cast iron T3 turbo manifold with the provision for an external wastegate, which came in handy considering the turbo does not have one on it. I picked up a Wyntonm 38MM wastegate and adjustable boost controller. The blow off valve is a cheap Ebay one, and I dont know if it works, but came with a cast aluminum 2.5 housing for easy installation. The 2.5 intercooler piping and front mount intercooler came from CX Racing. The pipe kit came with 16 T bolt clamps, 8 blue silicone couplers, and 8 pieces of pipe. I cut the pipe custom to snake around the backside of the engine around the oil pan to the passengers side of the intercooler, then from the drivers side through the hole in the body straight to the throttle body.  I also have a 3 mandrel bent pipe kit from Colombia River and a 3 flex pipe from CX Racing to go along with the turbo kit if youre interested.
Im moving on to bigger projects and need this gone. I lost interest in finishing it and just want to get into a different project.  I will sell the car as a whole turnkey setup for $2500 turbocharged or $1500 naturally aspirated. Or the prices listed are what Id like to get for everything parted out.
.74A/R cold, .64A/R hot, T3/T4 turbo,4 inlet/3outlet-$350
CX Racing 2.5 mandrel bent aluminum intercooler pipe, powder coated black, with blue silicone couplers and T-Bolt clamps-$125
CX Racing FMIC, 2.5 in/out, 22X6X3-$125
Wyntonm 38MM wastegate w/adjustable boost pressure regulator and dump tube kit-$120
Type RS blow off valve w/2.5 cast aluminum adaptor-$20
Cast iron turbo manifold w/ wastegate provision-$150
3 short ram intake off Buick Regal T-Type w/filter-$25
2.2L Ecotec Bare block w/ARP Main Studs-$175, less studs $75
2.2L Ecotec crankshaft, knife edged, polished STD/STD with bearings-$150
2.2L Ecotec stock cylinder head, no valvetrain-$75
Eagle H beam rods, brand new in box-$225
17 Drag DR-14 wheels with tires, one tire needs a valve stem, and the tires are the wrong size for a Cavy-$300
KYB GR2s with Megan Racing springs-$275
Control arms, powder coated, welded seams, urethane bushings-$50
Sub frame, welded seams, powder coated-$75
3 mandrel bent aluminized pipe-$150
CX Racing 3 flex pipe-$20
2 sets 2007+ COP coils with Cobalt engine wiring harness-$30
2003 LSS rear bumper w/ mounting brackets, fair shape-$40
Stock Cavy/Fire springs-$10
2 spare gauge clusters-$15 for both
AEM CAI, just aluminum pipe, no filter-$35
1pr. Sunfire SE/GT side skirts, fair shape-$35
1 Getrag F23 Differential, nothing wrong with it and nothing modded on it-$45
Misc Ecotec Engine parts: cam covers, timing cover w/oil pump -$25
Any questions feel free to PM me or email me @ mythod99@gmail.com. Thanks for looking
Project Resurrection is in full swing!
Sold some stuff, still got all this to sell. Won't be turn key anymore, this has become a full blown part out. Will sell the shell for $350 with clean title. Also have a complete, ready to run Ecotec engine, rebuilt and ready to roll with new timing for $200.
2.2L Ecotec Bare block- $75
So I found out my Craig's List ad got deleted...AGAIN!!! LAME!!! So anyway, this is what I've got left.
2.2L Ecotec Bare block-$75
Control arms, powder coated, welded seams, urethane bushings, new ball joints-$50
Complete Ecotec Engine, ready to run, new timing, stem seals, gaskets and ARP head studs-$250
Getrag F23 5 Speed Transmission-$250
Transmission mounts, powder coated w/poly urethane bushings-$55 for both
2000+ Stock Headlamp assemblies with Clear Corners-$90
2000+ Stock Tail lamps w/outside aftermarkets-$75
2000+ Trunk Lid, no damage or rust-$90
2000+ Hood, no damage, very little rust-$90
2000+ Passenger's Door, no rust or damage, has M3 RVM with amber/blue LED, stock mirror included-$125
2000+ Passenger's Fender, no rust or damage-$45
KYB struts and springs and control arms sold!
May be interested in the control arms here shortly...how much to ship to 21666?  too bad that subframe is so heavy and big.
The control arms were sold last week, with the suspension. That and so everyone knows, I'm going to keep the sub frame and sway bar. All I really have to sell is the body parts, lights, and the remainder of the turbo kit. Wastegate, BOV, intercooler, intercooler pipe, and the Buick Regal T-Type Short Ram with Filter. Oh, plus the engine and transmission. And the shell will be getting scrapped soon, just gotta get the body parts stripped from it and away it goes.
WooHoo, Engine and Trans sold this week. Now need to sell the rest...anyone interested?
I am interested in the AEM CAI if you can verify it for sure has a CARB number on it. Also, if it does, where would I get a filter for it?
You can use just about any filter...Fujita, Injen, K&N, Spectra, even a cheap EBAY knockoff will work, just has to be a 2.75" inlet. Unfortunately it does NOT have a CARB number on it....I'm guessing you live in CA, huh?
Ya. I didn't pass because my K&N doesn't have a carb number, and neither does any of my exhaust pieces.
LAME...sorry man.
As in Engine Cradle?
Got some Pics?
Would you be willing to ship?
This part is too big to ship. But I acutally mean to remove that. I'm planning on installing in on my Sunfire.
WoW...no one's even partially interested in my partial turbo kit?
.70A/R cold/.64A/R hot Garrett Knockoff Turbocharger-$250
Well, I did a complete inventory of the turbo kit. Here's everything I have:
1 Turbocharger-.70A/R cold-.64A/R hot, T3/T4
1 38MM Waste gate with dump tube
1 Blow off Valve with 2.5" adapter
1 FMIC-core measures 27"X3"X2.5" in/out
2 3" Hose clamps
1 4" to 3.5" silicone reducer-on turbo inlet
1 2.75" to 2.5" silicone reducer-blue
1 90 degree 2.5" silicone coupler-blue
2 45 degree 2.5" silicone couplers-blue
6 straight 2.5" silicone couplers-blue
19 2.5" stainless steel T-Bolt clamps
1 straight aluminum 2.5" pipe-powder coated black
4 90 degree mandrel bent aluminum 2.5" pipes-powder coated black
2 45 degree mandrel bent aluminum 2.5" pipes-powder coated black
1 3" mandrel bent short ram intake-fits Buick Regal T-Type-comes with filter
1 3.5" 45 degree silicone coupler-blue
1 straight and 1 90 degree mandrel bent 3.5" aluminum pipe
The intercooler pipe and 3.5" pipe were all custom cut to fit from the turbo to the intercooler to the intake, and the 3.5" was the intake for the turbo inlet.
I also still have the following:
2003+ Base Rear Bumper Cover-$35
Well, I'm down to just the turbo kit. Someone came and got the shell last week, and took all the good body panels.
2 3" Hose clamps
2000+ Stock Tail lamps, outsides,  w/outside aftermarkets-$75
Well guys, thanks a ton. All is gone and sold. The shell went a few weeks ago and I met a guy in St. Cloud to sell the turbo kit. So yea. Now onto the next project...planning on keeping you all informed!
