DOES ANYONE KNOW WHAT BELT I CAN USE TO GET RID OF THE A/C COMPRESSOR ON MY CAR I USE IT FOR DIRT TRACK RACING AND WANT THE A/C COMPRESSOR GONE
SEARCH IT'S BEEN COVERED BEFORE
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
OH MY GOD!
SEARCH SOME.
-MD- LD9 wrote:
"No bypass Pulley".... belt size should be 345K5, but it doesn't fit use a 350K5 belt. All belt manufacturers are different. You might need a longer size belt.
Also...
GM bypass pulley 2.4L p/n # 24574519
Just because...GM bypass pulley 2.3L p/n # 22533199
Hope that helps. Also removing all your ac junk I mean lines, pump, condensers and all...... only weight in at 33 pounds. FYI.
I have run my 2.4 with the bypass pulley and just a belt. I have had better luck with the bypass pulley, and stock belt.
Edited 1 time(s). Last edited Tuesday, July 28, 2009 11:02 AM
thanks big help
