-Autometer Phantom Series electric oil pressure gauge (BRAND NEW) $80 picked up - $100 shipped
-Autometer Phantom Series EGT Gauge (BRAND NEW) $80 picked up - $100 shipped
-Inovate LM-1 Wideband (BRAND NEW) $250 picked up - $275 shipped
-SSBC 12" single piston rear big brake disk conversion with black powder coated calipers (not even 1000 miles on them) rotors are partially painted black, you can see in the pics the pads aren't even worn in yet, there is a close up pick of the one line, there is very small tear in the plastic outer layer, it does not leak, the line is not punctured, its just the plastic coating, you can put some tape over it of a small dap of super glue or silcone or whatever or if your that concerned you can waste your money on a new line $550 picked up - $600 shipped
-Alpine Type R 12" subwoofers (2) in a new sealed box (subs are wired to a 2 ohm load) $175 pick up only
-JSP/Carbon Fiber Tech 03-05 OEM style carbon fiber hood WITH Sparco hood pins $400 pick up only
-Random HID stuff, S2000 projectors/housings  (one is taken apart), there is bulbs and ballasts etc, same stuff I sold before only to have the buyer ship it back for a full refund since he said one ballast was broken. So here it is... sold as is what you see is what you get, one complete setup was verified to work, one I guess didn't. So take it or leave it, I'm selling it for cheaper then what you would pay for S2000 headlight/projectors alone. $100 picked up - $130 shipped
-Brand new Ken2.2 subframe brace, never mounted or installed. $40 picked up - $55 shipped
-04 cavi stock trunk, has holes form lights and spoiler etc.. but comes bare - $20 picked up
-stock vaccum line for an eco going form FPR to intake - Free or goes in the garbage
-stock cav cargo net - $5 picked up - $10 shipped
-stock ecotec valve cover $40 picked up - $55 shipped
-Saab turbo (ecotec) engine cover - $10 picked up - $25 shipped
-Pair of stock cavi fenders off an 04, metal is in good shape, they need paint $50 pick up only
-Kent Moore Ecotec cam tool. Holds cam gears in place while you swap the cams so you don't have to mess with cam timing or anything like that. Makes a cam swap a VERY quick and easy job, sells for $288 new...
http://www.etoolcart.com/index.asp?PageAction=VIEWPROD&ProdID=7203. This one is brand new never used. I'm asking less then 1/2 price $120 picked up - $135 shipped
- pair of outer tails 00-02 style, kinda rough, lightly scratched and the weather stripping is pealing - free or goes in the garbage
-full set of 02 cavi tail lights in pretty good shape - $25 picked up - $40 shipped
-rear mudflaps for a cav, e-bay said they fit an 04, they didn't... not sure what they fit $5 picked up - $20 shipped
-those little rubber things that fit inside the back of the fender kinda in the door jam, off an 04 - Free or goes in the garbage
-exhaust flanges with gaskets - $10  picked up - $25 shipped
-Nitrous Express "main line" solenoids and bottle feed line (no bottle, no switches, no nozzle or jets), I got them used but never used them, they just sat for a long time, as is. $60 picked up - $75 shipped
-washer fluid pump off an 04 - $20 picked up - $35 shipped
-cavi rear bumper brackets - free or goes in the garbage
-misc. wiring, power wire, ground wire, speaker wire, fuse holders, terminals etc.. look at the pick, if you need something make an offer
-stock 3rd Gen spindles, when you do big brakes you need to cut off the ears on the spindle that the pads normally sit on. Cut up these and save your stokers, make an offer
-diamond shaped mesh, one is black plastic one is aluminum - $5 each
-cavi manual passenger mirror from a base model, all black/stock unpainted finish, it has very slight surface scratches on the top of the housing - $20 picked up - $35 shipped
- basic layout for rear seat delete, made out of MDF, not finished, just a starting point to build off of - make an offer and pick it up
