No asking prices, reasonable offers will be accepted.
People who will pick up get priority, I will ship smaller items at buyers expense.
-04 Cavi LS Sport  trunk - silver
-04 Cavi hood - brand new paint, sand drift metallic
-04 Cavi drivers side fender - sand drift metallic
-04 Cavi passenger side fender - sand drift metallic, scratch professionally fixed, still has primer where repair was done
-04 Cavi base model trunk - fresh paint- sand drift metallic
-04 cavi center trunk lightbar
- Basic layout for a rear seat delete, made out of thick fiberboard, very strong base to build fiberglass enclosure/amp rack for the back
-Alpine Type 2 12" dual 4 ohm
-Alpine 500 watt RMS mono amp (meant for above mentioned sub, perfect match
-Alpine type S 6x9's - one of the wires broke off from one terminal, you just just need to solder on a new wire to connect speaker wire to
-00-02 tails
-cavi rear bumper brackets
-rear bumper filler panels
-03+ billet front grill
-RDFabs harness bar
-stock cavi non power passenger mirror - VERY minor scratches that you can see when the light hits it right
-all seat belts and buckles form an 04- tan
-rear mud flaps- wont fit 03+, meant for base models
-Alpine IVA-D300 fold out touchscreen with extras
-stock eco serp belt, good condition
-complete HID setup, entire S2000 setups, housings, projectors, bulbs, ballasts, etc.. wired for an 03+ plug it into factory socket and connect one wire to power and one to ground - this is not something i want to get rid of but I will IF the price is right
-04 cavi stock front tan seats, no brackets or sliders, just seats
-random stereo wiring, power wire, speaker wire, terminals, fuse block, fuses
-stock 03+ headlight bulbs, used for about 5K miles
-Passat headlight projectors
-Passat fog light projectors with shrouds, bulbs, pigtail harness, and bulb holders
-AEM clutch fluid bracket - fits 03+ I think it fits all 3rd gens though
-02 LS sport muffler
-Toyota cav trunk liner
-both front spindles for a 3rd gen - don't wanna hack up your stuff for big brakes, hack up these, I believe they came off Lowfires car
-set of 4 tan rubber universal floor mats
-graphite rear OEM carpets floor mats
-graphite stock triangle piece thingies from an 04 cav that fit in the rear seat to trunk opening
-stock 04 TB
-stock 04 exhaust manifold, couple broken studs that would need to be replaced
-04 cav cruise control module
-RKSport billet F-body pedals, manual trans, 3 pedals + dead pedal (don't ask LOL)
-Bosch BOV from Hahn stage 2 kit
-random couplers
-stock rear springs
-section of intake piping for vacuum line and breather hose
-universal angle eyes
-stock washer fluid pump
-Weapon R METAL TB elbow, smoothed out a bit on the inside, stock is about as smooth as a mountain range,
-Powerslot rotors - used for about 4K miles before switching to big brakes
-Hawk pads - used for about 4K miles before switching to big brakes
-SS front brake lines - used for about 4K miles before switching to big brakes
-front stock calipers - 25K on them
-Freedom Design short antenna - black
-stock base model 04 radio, AM/FM, no cd or tape
-Alpine 1000 Watt RMS amp
-2 type R 12's in a sealed box wired to 2 ohms, perfect match for above amp
-roll of sound deadener - not asphalt based
-Spal 40# shaved door kit
-all factory 04 a/c parts from the firewall forward, compressor, condenser, all the lines
-car show sign board with removable plexi to but your cars picture/info/whatever in there.
-2 14" steelies
-2 14" wheels of an old cav
-Addco rear sway bar
-04 rear bumper foam insert thing, the crush guard, top is shaved down slightly
I think I listed everything LOL. Anyways, pics.
56K is so F'd
