I need a used decent ld9 head.
i have one
slight gouge in combustion chamber but will work fine  pm me with an offer
I've got two.  Both slightly damaged but can be easily repaired.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
I have a couple..... depends on what year head you need.
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
i have a bare 2001 head with less than 12K on it.
Chris
'02 Z-24 Supercharged
i should be able to use that 2001 with little modification
... i know GM says its OK to use a new head on a old block, but not a old head on a new block.... weard
Chris
newer?  IDN
Chris
Taetsch Z-24 wrote:... i know GM says its OK to use a new head on a old block, but not a old head on a new block.... weard
Chris
i have a 96 head on my 00 2.4 block and have had no probs
HEY!  I didn't say it wouldn't work, I'm just saying GM says not to!
Chris
Taetsch Z-24 wrote:HEY!  I didn't say it wouldn't work, I'm just saying GM says not to!
Chris
i no i wasnt yelling at you, i was just saying that mine works
do you know why gm says not to, or any reasoning as to why they say that?
I'm going to guess, they fixed or just bettered the casting, help it not to crack\warp.
but what do i know.
Chris
well, I just don't want to install it. how fast can you guys put a new head on?
the reason is the different cooling passages...... from what I've heard.  The older head/newer block would run ''hotter'' then it should.
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
head swap.... 5 hours tops
Chris
wow thats impressive. I've done a head swap in beretta HO but theres alot more room than a jbay.
If you're doing a turbo build, I've got one that I started taking the hum between the exhaust valves out because of a deep gouge in one cylinder. will let it go cheap if your interested.
Project Resurrection is in full swing!
