.........daily drivers with Eibach Sportline springs and kitted????  If so have you had many problems with hitting shat in the winter?
I messed up my Koni Yellow / Ground Control Install and am looking at some lowering springs now..............@!#$!
i have to ask.....
what happened to the koni g/c install?
i have sprints, but i like them they have a nice drop but if u where looking for a more agressive spring and yet a nice ride height id go with a tein s tech
Cody I #@$% up my install.  I forgot to put the sleeve on before shoving the Koni insert in the stock front strut housing.  I have no idea how I would get the Koni out without messing it up.  Luckily I didn't cut the perch off yet, so now at least I can use lowering springs.  I was so pissed, trust me!!!!!
I was going to try and take out the screw in the bottom just a little and hammer on that to pop the Koni out, but I got too scared.  I think that I would strip out the threads.  I'm not sure how else I would be able to get the Koni out?  So I'm stuck getting some lowering springs...........
shane..that's my setup and its perfect~
ur kits lower then mine though..keep that in mind~
Lance your back!!!  Yeah, I was going to ask you about it, but I thought that you were still in MayHeeCo!
I wanted these damn Ground Controls installed so bad!!!  Hmm, otherwise I'm thinking the Tein S-Tech's.....................or ProKit????????
i have s tech and love them, i haven't had anything else to compare to but still great springs
http://www.cardomain.com/ride/2194936
He is on the eibach sportlines with the razzi kit, i have the sport lines as well but i only have the factory gm ls sport kit
shows you the space between the tire and fender about two finger gap i love it so agressive looking and im looking at getting the razzi kit as well.
