i start my car let it run when i step on the gas my interior light blink and dim and so does my head lights it has a new alt.
hmmmmm, u may want to check the operator of the car
te he he ya know I'm just messin'!!!
~Heather
****new sig coming soon!!!**** (hopefully)lol
"I'm the girl your mother warned you about" te he he
Quikchk wrote:hmmmmm, u may want to check the operator of the car
~Heather
either that or check your fuses. idk, just guessing there.
sounds like a possible loose ground..... ?
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
I assume you checked your + and - connections to your battery?
dan
Get 'em Jim!
do you have under drive pullys ? a huge system with out a cap. ? or check your battery terminals if there is any corosion that might be your problem
http://www.myspace.com/modifiedscc
no system not a fan of them, and no pully for a 2.2 new battery also.... so idk grounds look good idk where the engine to body ground is on a 2.2 anyone wannna tell me ..
ask "" spotabee "" he will be able to tell you probley what wrong with it if he cant then ask "" Skinny J "" i know he will be able to answer any questions you have.
the ground from the battery is eather right to the body a few inches from the battery tray there is 2 of them . i would strongly recomend grounding your tranny (tranny bolt ) to the body also there r no decent engine/tranny grounds on the 2.2 use a 4ag or a strap ..........also take a look at your plug wire they might be arking out , use a spray bottle full of water and spray them down with the engine running and look for sparks and listine for clicks or ticks every time that cylender fires ...
