Alright well if you checked the jacked/wrecked forum you would know my car is totaled........I am moving on....buying an A4 and a new Rocket......and no I wont touch the A 4.  just rims, body kit and some @!#$...but that motor is off limits...so I have a 2.3/2.4HO Hybrid motor with a 10.2:1 compression ratio....forged JE pistons, Eagle forged rods, Lightened Crank, Clevite 77 maint and rod bearings, machined oil pump for higher volume, 2.3HO head, stainless steel valves, brand new guides, brand new seals, composite metal gasket, 2.3 LO intake camshaft, 2.3 HO exhaust camshaft, power steering block off plate, custom Turbo Manifold 60-1 turbo charger, t3 exhaust, t4 compressor, 60-1 compressor wheel with a .70 a/r compressor housing, tial 38mm wastegate, prebent exhaust from turbo to where cat should be, wastegate external dump, all oil lines and fitting, custom made front mount intercooler, all charge pipes with couplers and clamps, HKS SSQV Blow off valve, Greddy Profec B boost controller, Greddy Emanage with all sensors, and all wire harnesses which I preassembled and never installed, Custom built Race tranny, welded differentail, bigger pump, Redline stainless steel clutch packs, 3500 RPM stall torque converter, HO intake manifold, 2.3 HO throttle body, corbeau Race seats, triple guage pod, boost guage, EGT guage and sensor, oil pressure gauge and sensor, auto trans interceptor, RK sport ram air hood....painted 6 months ago never saw the road, stock wheels, 15inch MT drag slicks, Fuel rail with pressure gauge threaded into rail, casper electronics adjustable fuel pressure regulator, 2.3HO injectors (brand new), accel 83lb per hr injectors, fuel tank with 255LPH walbro pump and fuel sender assembly has been modified to avoid fuel cut issues, I also have a red LED underbody kit never used, as well as a ton of factory engine and tranny parts...I also have a half assembled 2.5L stroker motor, any question or interests let me know please.....Its Been a blast...thanks
Goodbye Bobby, May God grant you the peace you never found in life.
“Here's my counter-offer to your counter-offer: go f**k yourself.”
—Al Swearengen
anyone can take the profec for $150.00 E-manage for 600 turbo kit for a G note
—Al Swearengen
how much for the engine?
<img src="http://home.insightbb.com/~dvboard00/sig_construction.jpg">
How much you want for the injectors?  Very interested ..
Engine as is with everything bolted to it all sensors attached...turbo attached and everything ready to just drop in....this guy was offer 4500 but he's jerking me around with @!#$ so @!#$ it $3500 and its yours....I'll crate it up and send it out........for the injectors they were 125 new and they are basically new and clean 300 bucks for the set with O rings and clips
—Al Swearengen
do you have interior pieces for sale?
i'm baaaaack!!
Everything is for sale
—Al Swearengen
Rear deck cover?  Without center brake light?  What color?  How much?  Cool.  Peace!
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.jpg">
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/mnjbo2.gif"><IMG SRC="http://registry.gmenthusiast.com/images/neo32843/Lil D.gif"><IMG SRC="http://registry.gmenthusiast.com/images/neo32843/mnjbo2.gif">
To whom it may concern... Coming soon: Premium Membership!
ok rear deck lid is black no center brake light and lets say 50 bucks, charge pipe alone 600$ or take the whole kit for a G, stock wheels $250, hood is the RK sport ram air hood already painted and finished...$500
—Al Swearengen
what color is your interior and how much?
i'm baaaaack!!
Black interior.....what do you want from it???
—Al Swearengen
dash, doors, headliner, rear seats, front seat brackets.
thanks.
i'm baaaaack!!
Ill pass on the rear deck lid for now.  If I get money and noone has taken it ill be back.
Sorry to hear about your car man, do you have your stock hood still? and how much for the driver's side fender? I am also interested in the inside door panels but I think kurt wants em so I'll consider myself next in line for those.
stock hood is long gone and lets say 100 bucks each for every other body panel....fenders, bumpers, rear quarter panels, roof, 300 for the trunk and 500 for the hood....75 bucks for the side skirts, glass is for sale too which btw is all new except for the driver side rear quarter window, interior carpet....corbeau race seats, back seat, dash peices...center console, race tranny, fuel system and everything else is still up for sale.....I just bought a new rocket a couple hours ago so it would be nice to sell this @!#$ off quick and be done with this chapter in my life
—Al Swearengen
what shape is the radiator in?
I have been plowing snow with mine, and it got damaged, I need one that is in good shape and is not packed full of nasty corrsion and buildup
'99 2200 LS CX1 Sport
