car has 130xxx pretty much anything on the outside or front suspension is useless, it does have good headlights, right front corner and tail lights, motor starts and runs fine, and then has all the interior which is charcoal, the seats have normal wear on them and are charcoal with blue spots, make offers on everything and anything would like to sell the engine and trans whole
Hey can I get that heater hose piece from you?
its not the same J....... 2.2's have different hoses.....
I'd almost be interested in the whole damn car........ I have a front suspension, and some body panels........
Brandon..... did you get that mount today?
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
yea i got that mount thanks, every outer panel, the engine subframe and a-arms are all junk.... i bought the car for the firewall...
hmm.......
2 door? I need front and rear glass for Karo's shell...... been tossing around the idea of turning that into a winter beater...... I have a full 2.4 drive train for it, minus axles....... needs an interior, but we have most of the drag car interior still..... I just need something to drive other then my Z...... then maybe start rallying it
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
LOL. yea its a 2 door, i have joe kernifics long axle from his car wont fit in my getrag cause its 1" too long i have his short one on my car tho... and i think i have another stock short axle as well ill check when im at the shop today, i also have a complete 98 z24 5spd harness with cluster reading 40xxx miles
axle didnt work? we have Isuzu axles in a getrag........ and getrag axles in an Isuzu (dont ask
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
yea i have 1 set of isuzu axles, and the axle from joes car, its a 2 piece axle has a solid shaft then a short regular axle, when jeff tried putting in on his car couldnt get it to work, maybe ill try again over the winter when i pull the motor and trans
