LSJ injector roll call. - Performance Forum
Monday, October 26, 2009 10:36 PM
Im curious.
How many people are running LSJ injectors with 03+ fuel rails? How many would be interested in injector cups that actually fit the injectors?
Post up if you are.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Re: LSJ injector roll call.
Monday, October 26, 2009 11:17 PM
I'm running them just fine with my stock injector cups.
Tuesday, October 27, 2009 7:24 AM
X2
z28guy(KGM BEOTCH)
Tuesday, October 27, 2009 7:36 AM
I want pics, because my LSJs were no where near close to fitting with my 03 rail. They just "hovered" above the cups.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Tuesday, October 27, 2009 10:19 AM
Tinkles wrote:I want pics, because my LSJs were no where near close to fitting with my 03 rail. They just "hovered" above the cups.
X2
I tried mine in my 03+ rail and bolted down I could wiggle each injector with my hand.
Ended up switching to the 02 fuel rail.
I would be interested in getting some cups tho!
Tuesday, October 27, 2009 10:23 AM
I have put them in a 05 car. No problems. If you are having problems then shave the mounting tabs and you should be good.
Tuesday, October 27, 2009 11:34 AM
Mine fit just fine. no problems at all. (2003 fuel rail and everything)
Friday, August 12, 2011 10:51 PM
Back from the dead...Did anyone ever end up making some sort of spacer or larger cup, or is the washer method pretty much the most popular method? If so do you know the exact thickness needed to make up for the height? Was hoping maybe by now someone had cross referenced another type of spacer for another vehicle or something but havnt heard anything about this topic in a while. Thanks
Friday, August 12, 2011 11:46 PM
Washer method worked great for me!!! 2 washers under each cup and I've had no problems at all.
Saturday, August 13, 2011 4:21 AM
No washer method has worked great on the cars I have used these on.
Saturday, August 13, 2011 4:49 AM
I make the injector cups that people are running on here. Pm me if interested in a set, they come with orings and fit just like stock but seat the lsj injector.
Thanks
Saturday, August 13, 2011 10:59 AM
kinda off topic...
I have LSJ injectors in my LD9, i modified the LD9 Injector Clips to keep them retained to the fuel rail without having them be able to be wiggled side to side...
Saturday, August 13, 2011 11:03 AM
Mystic02VA (GME Chat) wrote:kinda off topic...
When I had them on my car (LD9), I modified the top of the injector so the LD9 clips would hold the injectors to the rail.
Saturday, August 13, 2011 11:14 AM
I just went and got the stock cups out of a car in the junk yard
