What oil have you guys used to break in your engines and where did you get it at? would you use it again?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Basic non-synthetic 5w-30 oil, and a pint of Lucas break in oil additive. It has zinc which helps cushion lifters and rockers. I actually use it every oil change.
a High detergent oil, like normal Castrol.
Roofy wrote:Basic non-synthetic 5w-30 oil.
Right there. Used that for the first 500 miles and changed the oil, then used it again for the next 1500 miles and changed oil again. After 2000 break in miles, I swtiched to full synthetic.
2012 numbers - 4SPD
AUTOMATIC!!
I used Eneos 5-30 semi synthetic, only ran it for about 25-30 minutes.
like stated, normal non synthetic oil. i would reccomend GM E.O.S. its a very high in zinc oil additive designed for break in. GM part number: 88862586   you can buy it from GMParts direct or i usually get it from Summit.
super tech basic 5w30 oil and a bottle of e.o.s sounds like whats going in my new engine.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
you want the ceapes possible proper weight oil + a zinc additive for break in. change it at 500, 1000, 2000, and 3000 mile intervals.don't baby it, but don't beat on it. the rings need to see a good bit of pressure to seat properly, yet the cams don't like a lot of action early in their life.
Amsoil Break-In oil.. Great STUFF! !
