Do you need the EGR port in daily street operation , or can it be blocked off . Thanks.
I blocked mine off. You will have a check engine light though, you can disable it if you have HP Tuners.
Thanks for the information.
Manifold gasket designed for a non EGR car works for a block off. I had to do this with a 4-1 Header I was using.
Whats the point? They're cheap, dont effect power and normally give you better mpgs when they are working (unless you take it of and tune for the different with hpt then you can get even better)
Sponsored by:
Kronos Performance
whats the point? less weight, less wiring, less headache.
Less hassle when designing a header, doesnt really work to well with most intake manifold swaps, makes a mess of the intake manifold ports and valves, and they dont always work right.
ron seibenick wrote:Do you need the EGR port in daily street operation , or can it be blocked off . Thanks.
It can be blocked off on those that have it. 99 to 02 LD9's do not have it
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
ron-gm makes a block off plate for the LD9.
here's a pic...
