fuel injectors - Performance Forum
fuel injectors
Thursday, June 02, 2011 10:55 AM
if i get some 36ib injectors does it have to be tuned to run properly? if so how should i go about tuning it?
Re: fuel injectors
Thursday, June 02, 2011 5:25 PM
i think your exhaust O2 sensor will correct for the larger size, but i wouldnt trust my word on it, you should probobly post in the tuning forum.
oh and use the SEARCH button, lol, just kidding i hate when the only answer people give you is to search
Re: fuel injectors
Thursday, June 02, 2011 5:39 PM
Yes you need a tune.
Sponsored by: Kronos Performance
Re: fuel injectors
Thursday, June 02, 2011 10:40 PM
thats what i thought, i understand needing a tune i just hate the fact that i can go buy some bigger injectors which arent really that expensive but to actually use them i have to tune wiivh is very expensive... anyway thanks guys
Re: fuel injectors
Friday, June 03, 2011 2:58 AM
you gotta pay to play. no increase in power is free.
just like when i went to do cams, scored them for $250, but then all said and done would have turned into a $1500 assembled head job to use them to the full effect....
upgrade one thing, you have to support that upgrade which in turn makes you support the next upgrade which by the time you get all that done you are back to upgrading the original part you upgraded... vicious cycle.
Re: fuel injectors
Friday, June 03, 2011 3:00 AM
If you think getting hp tuners so that you can tune its expensive then you have no need for bigger injectors since you must think 3 grand for a proper cheap turbo setup is outrageous.
Re: fuel injectors
Friday, June 03, 2011 9:30 AM
no i understand paying for a proper turbo setup, but im not that far yet on my car. i just didnt understand 500 bucks for a set of fuel injectors but anyway, if i get ht tuners do i need to get a new ecu? or can i tune the stock one?
Re: fuel injectors
Friday, June 03, 2011 10:09 AM
Just an FYI dakota...
if your mod list is updated, you are nowhere near needing upgraded injectors. Injectors on their own wont increase HP
Buddy Club Ecotec Cavalier
* More to come *
Re: fuel injectors
Friday, June 03, 2011 11:05 AM
okay what should i do before that t hen? i was gonna get a throttle boddy and intake maifold soon as well.
Re: fuel injectors
Friday, June 03, 2011 11:15 AM
Alright now we're talking
put the LE5 manifold or SAAB manifold on, and you'll get MUCH better flow, MUCH better top end, and with the larger TB too, THEN you can worry about injectors. When you do that, you will need a tune, but you'll benefit a LOT from those mods
besides them, you can get some motor mounts / trans mounts. They help lay the power to the wheels much better than the stockers too
Full exhaust setup with header and hi flow cat would be great upgrades too
or if you want to turbo it... just get a turbo setup and be done with it
* More to come *
Re: fuel injectors
Friday, June 03, 2011 11:42 AM
so after manifold and tb i need tune? of after those and injectors? and btw thanks alof the the help, im new to most of the car stuff
Re: fuel injectors
Friday, June 03, 2011 11:54 AM
Yes, to get the most out of any mods your gonna want to get it tuned
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
Re: fuel injectors
Friday, June 03, 2011 11:57 AM
With the TB and Manifold, you should replace the injectors because the stock Eco ones are maxxed out at stock
If you didn't put injectors in, you'd be going the right way toward detoation
Then get the tune after the injectors
Also should up the redline at that time to ~ 7000 however, you should also get internals to go that high
BuiltNBoosted wrote:d... vicious cycle.
Exactly....
* More to come *
Re: fuel injectors
Friday, June 03, 2011 9:14 PM
okay.. so i should buy tb and manifold and injectors and buy hp tuners all at once? and make it one big project instaead of little ones? then after that work on internals, im guessing like heads and pistons? then tune up to 7k redline?
Re: fuel injectors
Saturday, June 04, 2011 4:10 AM
You don't need any internals for a 7k redline. To go above 7 you need to do a balance shaft delete and to go over 7.5-8k you need to build the head.
Re: fuel injectors
Saturday, June 04, 2011 8:58 AM
quote=Jay Corkit]Just an FYI dakota...
better atomization and flow matched injectors WILL increase hp.
Re: fuel injectors
Saturday, June 04, 2011 9:15 AM
z yaaaa wrote:quote=Jay Corkit]Just an FYI dakota...
True, but the 1 or 2 horsepower isn't worth 200-300 bucks.
Re: fuel injectors
Saturday, June 04, 2011 9:42 AM
Why not send a stock set off to:
Injector-Rehab.com (Watch vids)
or to RC Engineering
I think that a clean well balance flowing set of injectors would do wonders. Plus, no need to tune... Good luck.
NCR-SCCA
Re: fuel injectors
Saturday, June 04, 2011 11:58 AM
Leafy wrote:...To go above 7 you need to do a balance shaft delete...
Sorry I was saying that the balance shaft was an internal piece, and should be removed when you up the redline at anything over stock
if you want to get technical, you dont HAVE to do anything to rev higher... but odds are against you the higher you go
* More to come *
Re: fuel injectors
Saturday, June 04, 2011 2:22 PM
okay guys thanks that helped out alot, im going to just go ahead and save up for a le5 manifold and a tb and fuel injectors and hp tuners, and then make it one big project, after that ill make uping the redline and the balance shaft delete another project. thanks for the help
Re: fuel injectors
Saturday, June 04, 2011 2:25 PM
cool man
good luck
* More to come *
Re: fuel injectors
Saturday, June 04, 2011 3:17 PM
ill keep you posted on what happens , when i get everything i put up pics=] where can i buy everything from, like the le5 manifold? and what tb should i go with and i think i can get some lsj injectors from cobaltss.net
Re: fuel injectors
Saturday, June 04, 2011 3:29 PM
Wagonwes wrote:
z yaaaa wrote:
Jay Corkit wrote:Just an FYI dakota...
to YOU it may not be...
Re: fuel injectors
Saturday, June 04, 2011 4:36 PM
dakota phelps wrote:ill keep you posted on what happens , when i get everything i put up pics=] where can i buy everything from, like the le5 manifold? and what tb should i go with and i think i can get some lsj injectors from cobaltss.net
GM parts can order it for you
I believe Crate Engine Depot can order them as well
Or go to Cobalt SS sites and see if anyone is selling a manifold setup
As for your TB's there's a LOT of manf around. I've heard great things about SMG TB's. I believe OEM makes them too. (he's a member on here)
You can also get a machine shop to bore your stock one out, so long as they replace the centre as well, not just bore the top
Hope that helps for now man
* More to come *
Re: fuel injectors
Saturday, June 04, 2011 5:16 PM
okay, thanks alot jay
