Before I get bashed I did search for an answer
Befor I made a post but I didn't find ne answers for
My question I just wanted to know if ne one has used
Under drive pulleys on a 02 2200 and had ne luck
And wich ones they used also should I only under drive the crank ne leave
Every thing else witht the stock pulleys is it worth the troubles
Any advice would be greatly appreciated
Im running an ASP 25% underdrive. Its 39mm instead of the stock 52mm. The only issue I had was finding the right belt size, which turned out to be a Gates K050855 (855K5) belt. I also replaced the tensioner with a Gates unit. Good luck.
NCR-SCCA
Asp? Where do you buy these at? I don't want any eBay junk
Try google. If not look up www.ASPracing.com/gm.htm
I bought my pulley from James Cahill on this forum.
Not all ebay item are junk. Just got to shop smart. Good luck.
NCR-SCCA
Kody, You have a PM or try SummitRacing Part# 840097.
