Hello i am building an ld9 eagle rods .60 wiseco pistons extreme port ....ect i was just wondering what brand and size of injectors i should use. No turbo for now but will be one to come. Any input is welcome.
A lot of people run ford green stops. I believe they are 42lbs great for a good N/A build and a good starting point for a turbo build.
or the lsj injectors for a mp45 setup seem to do the trick. Will need more for a turbo setup but they are pretty easy to come by.
if money is of no object i recommend a set of rc engineering injectors.
If it takes forever.... I will die trying. Underdog Racing
What size/type of rc injectors?
honestly man without setting a goal and having the parts to actually achieve that goal nobody is going to be able to advise you on an exact size.
for an n/a 2.4 the low impedance ford brown tops work very well and give plenty of room for expansion. for boost, i wouldnt install anything less than a 440cc. and even then you'll prolly need to upgrade eventually because boost is addictive! LOL
Thanks. I just dont want to go too big so i have @!#$ty idle
I went with 935cc injectors. You tune the car to the injectors you have so i doesn't matter if you have 300cc ones or 1200cc ones. I know people with injectors over 1000cc and their cars run great.
