Wow its been a while.  I fully build my 2.4 about 6 years ago and abandoned the project ever since.  I've been itching to get it running again and started toying with it.  The engine is sitting in the bay with no tranny, brakes, etc hooked up.  The only thing wired is all plugs that would go to the engine.  When you turn the key, it doesn't crank at all or even try.  The gauges power up and you hear the fuel pump start.  The starter does work, but must not be getting the signal to crank.  Any ideas?  Not sure if there has to be a tranny for it to work or what the issue may be.  All appropriate fuse are intact...
12.6 @ 114.6 MPH
Know of a way to override it if that is the case?  It was auto, but since the tranny isnt in, it won't let you shift it into any other gears.  Looks as if its in park, but not entirely sure.
12.6 @ 114.6 MPH
Why do u want to start it without a tranny? Is it just to hear it or something? I know when I did my swap it was ground wires that were keepin it from runnin, Double check all the wires are in the appropriate places.
Good Luck
Ground wires seem to be alright. I'll double check later.  I want to start it to be sure it runs.  As of now, the only tranny I have is from a grand am.  The plugs are diff, so I'm not entirely sure how I'll hook it up if I even can.  Before I climb that wall, I need to know the motor works.
12.6 @ 114.6 MPH
--Glowin Cavy-- wrote:Know of a way to override it if that is the case?  It was auto, but since the tranny isnt in, it won't let you shift it into any other gears.  Looks as if its in park, but not entirely sure.
There's a purple wire that goes to the starter solenoid (or to the relay if the recall has been done to it).  I believe it needs to have +12V on it.  The purple wire would come from that safety switch, which has a yellow coming down from the ignition switch.  At least that's how it looks like on a 96 wiring diagram.
Or, you might be able to just locate the actual switch, and click/tape it down,  (not sure what kinda switch is on the auto ones though)
I don't think I would even try to start a motor that has sat for 6 years...At least check it all out first.
Mike wrote:I don't think I would even try to start a motor that has sat for 6 years...At least check it all out first.
why not? I have. I would check the oil, water. Prime the fuel system and look for leaks, built some oil pressure.
It does sound like the auto switch.
Screaming for Mercy!! wrote:Mike wrote:I don't think I would even try to start a motor that has sat for 6 years...At least check it all out first.
id be pulling cam towers and oiling them down too.
^ agreed. dont want to dry start the thing.  even that half second or whatever it is without oil can be detrimental to the parts that are metal on metal. now.. i dont know how long assembly lube is good for so i guess it could be ok if you were generous with the application of it...
6 year old build, eh? so this thing prolly has like JBP cams in it and some of the older stuff? care to share whats done?
got pics?
If it takes forever.... I will die trying. Underdog Racing
I say put the tranny, brakes, and etc in the damn thing and call it done.
Id atleast crank the thing over by hand a few times to make sure it spins fine.
u can start it, just fing the big yellow wire and the big purple wire that go to the transmission shift selecter they need to be hooked together, or u could always jump the starter solenoid
As everyone else said, you'll have to rewire the neutral safety switch for the time being.  Grab a diagram from whereever you can, and install a SPST switch (or simply a quick disconnect...) for the safety wires.  If that doesn't fix it, grab your multimeter and check out what's going on with the starter.
Personally, I like to make sure the engine won't grenade itself due to firing after sitting in the same position for 6 years. Stuff likes to gum up, rust/oxidation forms, blah blah. Especially when it sits untouched for 6 years. I'm just saying I would look it over very well before hand.
there is a pigtail that clips into the top of the tranny has a purpple and purple/white wire jump those too and viola!
LE61T PTE6262 Powered
Phil G wrote:there is a pigtail that clips into the top of the tranny has a purpple and purple/white wire jump those too and viola!
 Not seeing that combination anywhere...
12.6 @ 114.6 MPH
Wow man you still have this car? I thought you parted it out back in the day.
Nope.  I've thought about it several times, but its so close it would be a waste.  The problem now is, its been so long since I've messed with anything on it, I forgot a lot about it and what I all did to it back then... Its like I'm relearning about it.  It is amazing though how much things have changed around here though.  Back when I did my turbo setup, there were only like 5 other main members boosted... now I look and everyone is boosted and fully built.  Amazing how many are in the j-body game now.
12.6 @ 114.6 MPH
Random though.. you don't need a stereo connected to start the engine do you?  Not sure if there's any security connections involved...
12.6 @ 114.6 MPH
Nope, not at all.  However, it is a pre 2k and it does need the cluster for passlock.  Does it roll over at all, or nothing when you hit the key?
Matt, it has been a very long time since I talked to you.  Last time I did was at thompson.  If you need or want any help PM me, and I'll try and meet up and help.
Thanks.  When you turn the key, you hear the fuel pump kick on and everything prime up ready to go, it just wont crank.  If you jump the starter, it cranks with no start.  I imagine that's because there's still an issue preventing the ignition or injectors from firing, hence why it won't try to crank with the key.
12.6 @ 114.6 MPH
