ok so with the admittance of longer rods present in karo's slowfire miller performance built 259whp n/a ld9 motor i got to thinking....
so why cant everyone do it? now im no expert in this matter...and so i realize that changing the rod ratio is definitely something you need to know about before hand in engine building before you screw with it. i plan on getting all the information i can before even attempting to buy parts.
the way i understand it is this... you use a longer rod so it increases your cranking pressure,
NOT COMPRESSION, and in doing so you increase the time or "dwell" the piston stays at Top Dead Center.
also, from another perspective with the longer rod, its going to dwell at TDC longer which means its going to sit at peak cylinder pressure longer than a short rod.
you also need to adjust the pin location in the piston to accommodate otherwise the piston will ram right into the head on our zero deck height.
so... thoughts? concerns? insights? pj i know you know about this stuff... where you at?
Every time I scream "Release", I mean it, you know it. I feel the day. Black 7.
Not that I am going to change ANYTHING inside my block, im listening..........................
Hmmmm. You got me thinking now. And I don't even have the 2.4 anymore.
Till I buy another
well what u listed is the jist of it pretty much sir.......... it would make ur r/s ratio just a little bit better too going from a stock 1.54 (not so great) to a............. well i dont know the length of the "long rod" so i cant tell what exactly what it would be but the closer to 1.75 the better.
mike
i make neons go fast.........
I was always under the impression loger rods helped free up some energy similar to shaving weight off the crank or a lighter pulley. the rod arm angle is less therefore less friction is caused and less work is needed so you get an easier turning rotating assembly. ive read about chevy 350s producing up to 50 more hp with 6 inch rods instead of the stock 5.7s but every thing else is the same.
^^^ i have heard the same exact thing. this is what my dad has been drilling into my head for years, i just never really thought about it for a 2.4 before. that is until now that i read about it in karo's build....
ammfab-so 1.54" is stock 2.4 r/r?? anybody know what a 2.3 is? im throwing around the idea of using 2.3 rods. i know they are longer. hell... maybe even the pistons to if we can safely bore a 2.4 that far. only sonic testing the block will provide the information needed for this though.
You have to be careful swapping to longer rods w/o swapping cranks. You'll need different pistons with the wrist pins moved to prevent piston to head love.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
why would you need to swap the crank? im not talking about a stroke change here... just the rod length.
I didnt say you
needed to swap the crank, i just said you have to be careful.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
i just googled stock stroke and rod length for the ld9. i found the rod length to be 5.710 (145.0mm) and the stroke to be 3.700 (94mm). then to find the rod stroke ratio (r/s ratio) u devide the rod length byt the stroke and get 1.54.
when u increase the rod length by lets say .300" to get a new rod length of 6.010 and then when u do th emath again u get a new r/s ratio of 1.62 which is better. it decreases side loading on the cylinder walls like the guys mentioned above which will free up some hp at the same time ur kepping the piston at TDC (dwell) for slightly longer also under the cylinder pressure from the combustion to give it a little more thrust on the way down............ u know what i mean.
as for the new pistons......... yeah u will need new ones with the pin bores moved further up on the piston. they should be moved the same amount as the rod length increase so that it lowers the pistons back down to the original postions, to prevent them from running into the head.
in the event that u have enough room between the head and pistons after u put long rods in and u opt not to run new pistons (because u have enough room), i dont think it will effect the compression ratio at all becaue ur engine is still drawing in the same amount of air as before and the piston dome hasnt changed any. compression ration is changed by the piston dome not putting a longer rod or bigger stroke in.
mike
Edited 1 time(s). Last edited Wednesday, August 05, 2009 11:16 PM
woops......... double post.
mike
Edited 1 time(s). Last edited Wednesday, August 05, 2009 11:15 PM
think you got everything pretty well covered in here
yes some will help free up the energy used by the rotating mass
you can also alter your compression ratio with changing the rod length , by the piston pin height you get , you can get it at zero deck height , below deck or out of the deck which will also create head clearance issues , though bring the piston up higher above the pin center line , will bring you closer to smacking the valves if the chain or belt breaks
2.3 Stroke = 3.35"
2.3 Rod Length = 5.806"
The 2.3 r/r is 1.73. Hmm looks like i am making a good decision...
I dont think you can use the 2.3 rods with a 2.4 crank. You have to remember that the 2.3 rods arent as thick as the 2.4s.
jmarks82 wrote:2.3 Stroke = 3.35" 2.3 Rod Length = 5.806" The 2.3 r/r is 1.73. Hmm looks like i am making a good decision...
Yeah, the LG0/W41 keeps looking better and better.
Edited 1 time(s). Last edited Thursday, August 06, 2009 7:26 AM
jmarks82 wrote: You have to remember that the 2.3 rods arent as thick as the 2.4s.
Pretty sure 2.3 rods are thicker than 2.4's. 2.3's = 1.086 at the big end , 2.4's = .915 at the big end.
2.3 rods are 5.80 vs 2.4 rods are 5.61
Back in the day Mantapart had a long rod piston combo. I think Kenefic had it in his NOS motor before he went turbo
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Yeah 2.3's are beefier.
I wasn't a fan of just a pin relocation, personally. Eagle charged out the ass for my rods, lol. (Which is why when the first motor puked its guts out I was completely relieved the rods were in perfect shape... I just obliterated the pistons and pins)
The mechanics behind this are interesting... I had no idea that Karo had this done before me! I sure could have used some info, would have saved me some time and coin. lol
Is it a stock crank in there?
-Chris-
-Sweetness-
-Turbocharged-
Yeah i got confused.
I bet those rods were a pretty penny. But, with using the stock crank and 2.3 rods, thats still only a 1.56 r/r.
So in the end is it really worth it. Every bit helps but its not going to make a huge difference. This is where the cost might out weigh the gains.
Knowing Chris though, his crank is de-stroked to get that perfect r/r!
Actually someone else did it before Karo.
Here are the specs of Eagle Rods for both the 2.3 and 2.4. Looks like you could shave down the big end of the 2.3 rod to the width of a 2.4 rod. I am not sure I would want to do that to an aftermarket rod. Like Sweetness said, a one off set of rods are going to cost.
Chevrolet LD9 2.4L Quad 4.............Chevrolet LG0/LD2 2.3L Quad4
length: ----------------5.710 in......................5.806 in.
rod journal: ----------1.889 in......................1.889 in.
housing bore: -------2.0145 in...................2.0150 in.
pin size: ---------------0.866 in.....................0.866 in.
big end width: -------0.9120 in...................1.0860 in.
pin end width: -------0.9120 in...................0.8750 in.
thickness above pin- 0.200 in..................0.200 in.
typical weight: --------550g............................590g
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
i love this thread.
to to get the big boys talking makes me proud LOL
so.. gary.. are those pauter rods in your motor the same as karo's?
lol at you chris. im figured out one of your secrets. na na na boo boo.
at this point i am ready to admit that really the only part useful in an ld9 is the crank. lg0 > ld9 all day long. why even bother with a 2.4? put a 2.4 crank in a 2.3 and be done with life.
Edited 1 time(s). Last edited Thursday, August 06, 2009 10:52 AM
i wanna be in this thread. its gettin me all hot and bothered.
Don't forget to think outside the Quad4 box here guy's. Might be able to find rods from a small block v8 or a nissian or a mitsu or a v6 northstar or whatever that can be resized on the big end or bushed on the small end or you have your quad crank journals turned down some to fit a smaller rod on,cut the holes in the pistons for bigger wrist pins,etc.,etc..
We used to do silly sounding stuff to get what we wanted...
yea... i did that earlier today with a sbc rod and an ls1 rod my dad had lying around. the ls1 would probably be the right length improvement we'd be looking for but the journals on the big end are quite a bit larger than a 2.4's is. you could definitely bushing the small end and make it work, but the big end would take some ingenuity.
I'm not really adding anything, but keep in mind deck height is an important dimension too.
there's a formula for finding a bottom end combination that works.
you need the deck height (center of the crankshaft main to the deck)
then add HALF the stroke, the rod length (center of big end to center of little end), and compression height (center of wrist pin to top of the piston.. not including any dome/ dish) together and this must be LESS than the deck height.
Also keep in mind that any change in stroke must be reflected in the compression height by half, and any change in the rod length must be reflected in the compression height equally.
in other words, increase stroke by 4mm, decrease compression height by 2mm
increase rod length by 4 mm, decrease compression height by 4mm
(decreasing compression height means the wrist pin needs to moves UP, towards the top of the piston)
so whatever combination you change things, needs to be reflected in the compression height.
here's an article I often reference when people ask about rod ratio.. I've omitted the V8 specific talk so it mostly refers to engines in general
the rod ratio in a gasoline engine determines the piston dwell at TDC. the longer the rod, the less downwards piston motion will be the result of the rod angle changing.
if the crank rotates 10 degrees, then a very short rod will be at a greater angle than if the rod is very long. since the rod doesn't change length then some of the pistons downwards motion will be a result of this phenomenon, so the longer the rod, the longer the "dwell" and the longer the dwell the more complete combustion and higher cylinder pressure. The rod length is limited by other engineering concerns, like block deck height, piston height, and thus inherent stability, and resultant wear. and so on.
Rod Angularity
A longer rod reduces the maximum rod angle to the cylinder bore centerline. Less rod angle will reduce piston side loading; there will be less friction and less bore wear. Less rod angle also gives better average leverage on the crank for a longer period of time.
Piston Pin Height
A higher pin height will reduce piston rock and aid ring seal. please no screaming and name calling about anything about a tighter ring pack, we are talking about pin height and pin height only. Moving the pin closer to the center of gravity of the pistons makes the piston more stable.
Rings
As the compression height is reduced, the space for the ring pack also get reduced. This can be a problem on some engines. It is good for power to have the top ring as close to the top as possible, but this is limited to the strength of the top ring land. As it becomes thin, it becomes weak. High output engines (especially nitrous engines) need a thicker ring land to keep the cylinder pressure from pinching the top ring. In my opinion, if you have to compromise ring location, it would be better to run a slightly shorter rod.
Skirts
Shorter skirts are usually combined with a shorter piston for a longer rod, but they are not really related. There is no reason to reduce the size of the skirts just because the pin location changed. A shorter skirts are used to reduce friction and lighten the piston. The cost is a little less stability, but it is arguable that a lighter piston with a higher pin height does not need the extra stability. For a street car, I would increase the rod length if it meant a reduction is skirt size. Most of the things listed here are for competition motors to gain a few hp, not worth a lot of effort for most street engines.
Piston-to-Valve Clearance
A longer rod decelerates toward TDC and accelerates away from TDC slower than a shorter rod, so piston-to-valve clearances are tighter with a longer rod. This may require deeper valve relief's in the piston. A short rod is just the opposite, there is more clearance because the piston decelerates toward and accelerated away for TDC faster.
Piston Velocity
A longer rod reduces peak piston speeds slightly and delays peak piston velocity until the piston is further down the bore, which gives the intake valve more time to open more. Peak piston velocity is usually somewhere around 75° ATDC and since most cams cannot fully open the cam until at least 106° ATDC, it leaves the valve as a major obstacle when airflow demand is at its greatest. By delaying peak piston velocity, even if it's only 1 or 2 crankshaft degrees, it can allow the valve to open another 0.010-0.015", before peak airflow demand is reached. Not a huge help, but a step in the right direction.
Piston Acceleration / Deceleration
Reducing piston acceleration / deceleration from and toward TDC will reduce tensile loading of the rod, the number 1 cause of rod failure.
Intake Runner Volume
Since it is easier for an engine to breath with a longer rod, less runner volume is needed. This allows more room for an intake system (this is a very small gain, but is real).
Exhaust Gas Scavenging
A longer rod is moving slower at TDC, which reduces the speed of the exhaust gasses during the overlap period. This reduces the scavenging effect at low rpm and reduces low rpm power slightly (makes the engine run more cammie). A short rod on the other hand moves faster past TDC and increases the scavenging effect and help low rpm power.
Ignition Timing Requirements
Due to the fact that the longer rod moves past TDC slower, it gives the charge a longer time to burn. So you need less timing for peak power. Using less timing also reduces the chance of detonation; so higher compression ratios can be used.
Longer Rod Pros
Less rod angularity
Higher wrist pin location
Helps resist detonation
A lighter reciprocating assembly
Reduced piston rock
Better leverage on the crank for a longer time
Less ignition timing is required
Allow slightly more compression to be used before detonation is a problem
Less average and peak piston velocity
Peak piston velocity is later in the down stroke
Less intake runner volume is needed
Longer Rod Cons
Closer Piston-to-valve clearances
Makes the engine run a little more cammie at low rpm
Reduces scavenging at low rpm
Shorter Rod Pros
Increased scavenging effect at low rpm
Helps flow at low valve lifts (a benefit if the heads are ported with this in mind)
Slower piston speeds near BDC
Allows the intake valve to be open longer with less reversion
More piston-to-valve clearance
Can allow for a shorter deck height
Shorter Rod Cons
More rod angularity
Lower piston pin height (if the deck is not shorter)
Taller and heavier pistons are required (again, if the deck height is not reduced)
More ignition timing is required for peak power
some of this must be attributed to grape ape racing...
I've also read that unless you're seeing a change of at least 2-3% sometimes 5%, its not worth the effort.
so changing the rod length alone may not be perceived as any noticeable change (airflow changes)
but rod ratio was a big reason why I decided to swap the LSJ bottom end into the skwirl. The advantages of an engine that has the potential for higher revs structurally, better high-rpm breathing capability, less side loading, and improved OEM internals was more than enough to convince me.
