One in theory number 1 sounds like it might help although I think you would be hard prressed to see the reults on a cavalier on the dyno.
Number2 I doubt will help as the fuel flows through the line at a decent pace and they just are not exposed to that much heat. Once again in theory it sounds good but I doubt any real word dyno tests on a cavalier would show a gain.
Number 6 Does not apply to our cars as we don't have coolant running through the throttle body.
#1 and 2  it seems like they work on paper but i doubt you'd feel any difference.
#6 doesn't apply because as far as i know none of the 3rd gen j-bodies have heated throttle bodies.... not even the Canadian ones.
Cool.. Thanks guys! Just curious
#1, I have done before.Can't say I could really tell. I stopped doing it and can't tell.
Egad..
you will pick up roughly 1 whp, dyno proven time and time again
1 hp? Wow. That might be noticeable on a 60hp Honda. Yet, there's no dyno proof to be found at all on the site. What a dip @!#$.
i don't see number 6 helping much even on a V6 that has it
my L67 TB has next to no coolant going to it to see more gains i would have to remove it from the SC completely meaning i have to pull off the supercharger and block it off at the lower intake manifold
heres a 7 on a V6 or V8 paint the bottom side of your Lower intake manifold White. they say it reduces heat in the LIM, i say paint will peal and plug up a lifter or pushrod
JBO since July 30, 2001
i stopped reading once i saw he was working on a honda....that explained the whole write up...........1whp? wow...i think itll try it on my scooter where it will actually mean something
free stuff that does nothing
Color only has to do with heat from a light source...
Take to pieces of metal on painted white on painted black.  Put them in the oven they will both heat up at the same rate.
