did GM ever put an l61 or le5 in a saab? also if i were to take a turbo from a saab what would be the best saab to look for? any help or input is appreciated
No they never put an l61 or le5 in any saab. Any 03+ saab 93 new body style. The one with a lower case "t" are the low output versions, and the capital "T" has the high output turbo.
cool beans, thanks for the info
are you crazy? they put ecotecs into sabb's, i'm just not sure if they were 2.2 turbo ecotec's
(Tom) S/C Fire wrote:No they never put an l61 or le5 in any saab. Any 03+ saab 93 new body style. The one with a lower case "t" are the low output versions, and the capital "T" has the high output turbo.
Wikipedia wrote:
LK9 is a turbocharged 2.0 L— 1998 cc (121.9 cu in) — version of the L61 utilizing a reinforced sand cast aluminum cylinder head and reinforced internal components. It features an 86 mm (3.39 in) bore and stroke and a 9.5:1 compression ratio. Power is 210 horsepower (160 kW) at 5300 rpm and 220 lb·ft (298 N·m) of torque at 2500 rpm. Maximum boost is 12.3 psi (0.85 bar).
* 2003–present Saab 9-3
http://en.wikipedia.org/wiki/GM_Family_II_engine#Ecotec
It's basically the L61 destroked 2.2 with upgraded internals and a turbo. The turbo parts and manifold match up very well to the 2.2L L61 (which is what the OP was getting at anyway).
Shifted wrote:(Tom) S/C Fire wrote:No they never put an l61 or le5 in any saab. Any 03+ saab 93 new body style. The one with a lower case "t" are the low output versions, and the capital "T" has the high output turbo.
He asked a specific question and I answered it in a specific fashion. Yes the block is the same and that's about it.
and you are technically right that would be like saying did GM ever put the LD9 in the 95 Z24 the answer would be NO same thing, basicly he should have asked will a saab turbo work on an ecotec then we all could have said SEARCH instead
JBO since July 30, 2001
Should also mention that the swedes are crazy about ethanol, so it wouldn't be a surprise if the Saab version were also flex-fuel. Judging by that static-compression number, I'd guess it is.
Go beyond the "bolt-on".
Nickelin Dimer wrote:Shifted wrote:(Tom) S/C Fire wrote:No they never put an l61 or le5 in any saab. Any 03+ saab 93 new body style. The one with a lower case "t" are the low output versions, and the capital "T" has the high output turbo.
Saab has never made any flex fuel vehicle.
(Tom) S/C Fire wrote:Saab has never made any flex fuel vehicle.
Not according to what I read a few years ago... Said they made more power with less total percentage of enrichment under moderate to heavy throttle compared to a gasoline engine.
Ok, maybe they made a concept car or two, but they never made a production flex fuel vehicle.
And the AERO X concept they had was a JOKE. They brought that peice of crap to our dealership, lol, it had no suspension exhaust looked like crap, it was strait homemade @!#$ that spent most of the time in the bodyshop. One of the other techs heard the car idle into the showroom, he said it sounded like a 2.0l ecotec with a bad serpentine belt tensioner. /rant.
Where can I find a whole setup?
Basic to install on an L61 Cavy?
Buddy Club Ecotec Cavalier
* More to come *
can find them in junk yard or a the classifieds section on the board
Jay Corkit wrote:Where can I find a whole setup?
ur kidding right?
god man, i know youv'e been around long enough to search in teh boost forum. i mean, props for finding an old thread to use instead of making a new useless one, but seriously, a few quick minutes searching in teh boost forum and you wouldv'e found all the answers you could need.
Im doing the saab turbo in spring i already have the manifold.... its just a tdo4 14 or 15 t depending on if you use the B207L or the B207R..... i am going with the r turbo because its what i found to be more plentiful in my area... direct from a saab dealer the brand new turbo was only $600 so its really not a bad idea to buy a new turbo.... all you really need is the manifold and turbo and downpipe from th 03 and up 9-3 but you can use lsj FYI the supercharger tune is a pain in the ass to get someone that will do it.... been there done that now i use hpt.
The downpipe won't work from saab. You have to make it.
Not to knock the made in the USA attitude but the Ecotec engine was a mod of a Opel engine that has existed since the early 80's and the Saab Turbo engine was the basic for the LSJ.(note the bore and stroke,fellas)Hey, I don't blame you for starting your own thread as I'm having a hard time finding certain topics myself.
Ecotec, as offered in the USA, was all-new in 2002. While the "Ecotec" name had been used previously in Europe, the engine released here had not. Previous European Ecotecs were very different.
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
Isn't the Ecotec a progression of the old Pontiac 2.0 OHC that was also updated and used in the Daewoos as a 2.0 DOHC? Sorry if im just adding confusion here. Seems to me Ecotec is like v-tec just a name for technology on a bunch of different engines that aren't very similar. Like the 1.8 Chevy Aveo's/ Daewoo Ecotec is way different than the rest but similar to the new 1.4 Chevy Cruzs?
No...
Bill the L61 is almost the same as the 2.2L Z22SE in other countries such as The United Kingdom and Australia.
Right you are, MD.
To all: This is a very informative webpage, and can help you better understand the intricacies of the Ecotec engine name:
Ecotec History
Within the info on this page, one can see that what we refer to as Ecotec in the USA was an all-new design for 2000, related to its predecessors in name only.
Bill Hahn Jr.
Hahn RaceCraft
www.turbosystem.com
^^BHJr is indeed correct.
What's more I even have a picture that there is 1997-98 Sunfire GT with a prototype American Ecotec in it, I think it was S/C too.
>>>For Sale? Clicky!<<<
