Help to clairify LSJ injectors in L61 - Performance Forum
Monday, January 12, 2009 10:45 PM
I have looked around on jbody.org, ecotecforum.com, ecotecpower.com, and cobaltss.net for info on this.
I have seen Cody@RDFABS write up about the LSJ injectors working in the 03-05 fuel rail on the L61, but my question is will these fit in my 02 L61 fuel rail, or should i switch to the 03-05 fuel rail?
Thanks for any help reguarding this matter and thanks ahead of time for any help!
CHAD
Re: Help to clairify LSJ injectors in L61
Monday, January 12, 2009 10:55 PM
direct fit for 02 rail
Monday, January 12, 2009 11:04 PM
sorry to thread jack but. from reading that. i need to swap to an 02 fuel rail for a direct fit on my 03?
Monday, January 12, 2009 11:10 PM
a few have been able to run LSJ injectors by pulling the spacers up in order to take up the distance. it works, but.. not really a solution since the injectors aren't actually bedded firmly into something.
Tuesday, January 13, 2009 1:25 PM
Thanks PJ!!!
Also do they just plug in or do i need the LSJ harness. Thanks again.
CHAD
Tuesday, January 13, 2009 4:26 PM
plug and play, the only issue is the injector length.. but with the 02 rail, its a direct swap.
with the 03 you gotta mess with it a bit
Monday, June 22, 2009 3:50 PM
Fastfire, you're right! I don't have the clips for the LSJ injectors. Can I use my stock ones?
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
Monday, June 22, 2009 4:05 PM
Yes
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Thursday, January 28, 2010 5:08 PM
and Spacers? Does the 02 ecotec fuel rail need spacers to fit the LSJ injectors? I have the injectors, with their rubber seals, that's it. Anything else I need to swap them? Spacers, anything?
Thursday, January 28, 2010 8:04 PM
The 02 fuel rail doesnt need spacers
219whp - I <3 whine
Friday, January 29, 2010 10:07 AM
DaFlyinSkwir(LS61) /PJ/ OEM+ wrote:.. but with the 02 rail, its a direct swap.
make sure you get the hard fuel lines with the fuel rail. 03+ and 02 are not the same.
my carDomain updated 10/31/09 Forged and Supercharged
Tuesday, November 02, 2010 6:47 AM
are the lsj injectors 42# injectors??? or is that the stage 1 or 2??? i have a link on here in anouther thread to some lsj 42#'ers are those stock or staged??? still direct fit on an 02 rail??? harness??
Monday, November 08, 2010 11:52 PM
M2 Online
Lsj's are 36lb. The 42's i believe are the stage 1's but you can also get them through other places like zzp. I'm running the lsj's in my s/c'd ld9 and i love them.
Eat my shift
