Ive got the LD9 and got the alternator pulley from the GP. How do I get the pulley off while the engine is still on the car? There is little room for the ratchet and there is no way of putting something in the pulley to jam it. Any help would be appreciated.
Thanks a million
Try lowering the engine a bit (take off the motor mounts and use a jack) also an impact really helps getting the bolt off without it spinning
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
^^^dont go to that trouble......just take the alt out. its 3 bolts, a nut on the power wire and dont forget the plug on the bottom of the alt. (i had to repin mine after i ripped it out)
Why was I thinking crank pulley? lol yea if it is the alt pulley just take the alt out of the car....
or you could leave the belt on to give it pressure, instead of jamming something in it....
break it loose with the belt in place, then remove belt, and finish undoing pulley, unless you have it on to tight...
Why are you taking it off?
T-55 or T-50 torx bit, and an open ended or closed ended wrench works fine for me.
Leave the alternator on the motor or take it off. Its up to you.
HHR alternator....
Edited 1 time(s). Last edited Thursday, July 10, 2008 11:00 AM
I tried with the belt on and the belt just flexed. Can you take off the alternator without removing the intake manifold?
^^ If you are plastic man or Mr. Fantastic.
You have to take the intake off.
Esp if you did the H.o. mani swap.
I STILL have yet to mine on.
-M
Mastin get on it....before you lose it again.
hmm, i have never had to remove a manifold off an ld-9 to change the alt....
how much crap do ya gotta move to get the alt out ????
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
