Installed the upper mount today. It's freaking amazing but it turned into a pain in the arse job. Had to pull out the coolant resevoir, had to go buy a new bolt to put the cruise control bracket back on, didnt have any 15mm sockets. Had 14 and 16, but no 15 (???). All in all, it was worth it. Thanks a lot TTR and Aaron! Look forward to doing business with you again!
"You can only feed them semen for so long before their legs fall off."
if you think that is a pain....you have a harsh reality check ahead of you.
glad you like the mount though, I have heard lots of good things about it.
How do you expect to work on a cavalier without a 15mm. You really only need 5 sizes ..... 10mm, 15mm, 18mm, 1/2", & 9/16".
1/2" and 9/16"
somebody must have swapped out your bolts in ur car then.
10mm, 13mm, 15mm, 18mm, done.
Riddle me this... riddle me that...
I have 1/2 for my intake/exhaust bolts and 9/16 head studs!
Definatly the 13, damn yoru a gonner if you dont have a 13 with you.
Well, it wasnt hard at all, dont get me wrong. It was basically like putting a bolt through a board and tightening it down. Just a few bumps along the way i didnt expect. Next up is the lower and pacesetter header.
lol true its pretty easy to put it in, take like 5 to 10 mins, to bottom mount is fun with the poly bushings u have to force and squeeze them in there
I diddn't time it but I am willing to bet I did my ttr upper in less than 15 min. from opening the hood to closing it.
and doesn't just about every tool kit come with a 15mm???
Those so naive, so hard headed, so narcissistic, that think that buy their own efforts can single handedly change the world, are always the ones that do.
WHITECAVY(Almost there) wrote:Definatly the 13, damn yoru a gonner if you dont have a 13 with you.
werd, without the 10mm and 13mm, you cand do much
Well, it's mi padres garage. We have just about everything; i guess we just lost the 15mm. ha! All we need now is a car lift
are the bolt in the dash 7mm ? whatever the size .. thats a major one also.. from the dash to the wheel wells
z yaaaa (the riddler) wrote:1/2" and 9/16"
1/2 exhuast bolts and 1/2 valve cover bolts also
8 mm battery bolt
7 mm for int panles and trim
5.5 mm heater motor
t55 torx socket for seat belts
i can go on all day with what u need to take a j-body apart.
Mark Raimo wrote:z yaaaa (the riddler) wrote:1/2" and 9/16"
Those are 13mm. Every bolt on the Cavalier (at least under the hood) is metric. 1/2" is the closest equivalent to 13mm, which is why it works.
If you think the removal of a coolant resevoir is a pain try accidentally breaking one of the M12 motor mount bolts in the engine mount... yes it can be done and it's a royal pain in the a$$ to remove!
