smog and ps pulley delete - Performance Forum
Wednesday, May 14, 2008 10:47 AM
has any one done this and if u have what type of gains have u
gotin and has anyone done this with underdrive pulleys and
what size belt would u need to have
speed kills save lives drive a honda
Re: smog and ps pulley delete
Wednesday, May 14, 2008 11:24 AM
Your car doesn't have a smog pump... This isn't a 70s - mid 90s v8...
Also, just going off of this post alone, leave the power steering on. It doesn't seem like you need to make anything harder on yourself.
Wednesday, May 14, 2008 11:28 AM
I totally agree with ^^^
belt size should be in instructions or included with it.
personally...id rather have the AC.
underdrives will also add a minute amount of power, but would make finding the correct belt even harder.
Wednesday, May 14, 2008 6:39 PM
^Not to mention the low voltage at idle with all lights on problems to be had with auto trans models from using those pulleys. Huh, John?
Go beyond the "bolt-on".
Wednesday, May 14, 2008 7:00 PM
ps pump doesn't have any resistance when you're aiming straight anyway
Wednesday, May 14, 2008 9:26 PM
I have removed "smog" related parts and the ps steering as part of weight removal. I have the light weight factory size pulleys also.
It runs a lot smoother, but i removed about 300lbs the same time i added the pulleys.
I wasn't able to drive it in between so its hard to tell what did what, but yea ps would only free up power in low speed corners haha
