Im looking to hook up an after market water temp gauge and Im just wondering how does the coolant flow on a 2200, all I need is the direction of flow on the main hard rail, I will be able to figure out the rest!
Thanks in advance!
there is an arrow on the rail no?
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
no there isnt, so ..... does it flow from driver to passenger, or passenger to driver?
what does direction matter?
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
02 silver cavy wrote:what does direction matter?
He wants to know which side of the radiator is hot and which is cold...
It's going to flow out of the water pump, no? It's going to be hot going through the firewall to the A/C heater, no? I feel these clues are sufficient
fortune cookie say: better a delay than a disaster
The hard rail by the spark plugs? if so passenger to driver.
thanks so hardcore! thats all i needed, now time to go mount the gauge!
