Buying a performance radiator--What's stock radiator cap PSI limit? - Performance Forum
Sunday, December 30, 2007 1:15 PM
Hey,
I have one of those THERMOCAP radiator caps that is set to 16 psi. It has a built in temperature gauge. If knew to some people, check out Mr. Gasket Thermocap http://www.photofloods.com/store/auto-15723111-B000OF9LRO-Mr_Gasket_2471SDomestic_ThermoCap_16_PSI_SLVR.
I'm trying to find out what our Stock radiator caps are set to, PSI wise. I know the PSI limit helps the car maintain its normal temperature without overheating. Don't want to use this cap on new radiator or stock one for that matter if its the wrong PSI.
Thanks
www.cardomain.com/ride/595770
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
Re: Buying a performance radiator--What's stock radiator cap PSI limit?
Sunday, December 30, 2007 1:59 PM
The cap we used on my custom tank was a 15 psi unit.. which is what I 99.9% believe stock is.
-Chris-
-Sweetness-
-Turbocharged-
Tuesday, January 01, 2008 10:48 AM
I think you're right... If I purchased a 16 psi cap; make any difference?
Tuesday, January 01, 2008 7:26 PM
since when do we have radiator caps...?
we have the cap on the reservoir, but no radiator cap...
Tuesday, January 01, 2008 7:48 PM
DaFlyinSkwirl (PJ) - APU wrote:since when do we have radiator caps...?
There is a cap on the radiator, its hard to see, but its there.
Tuesday, January 01, 2008 9:17 PM
on a 2.2 or 2.4 ive never seen one on my 2.4
Tuesday, January 01, 2008 9:29 PM
no matter the engine..there is no radiator cap..just a resevoir cap...i even have the griffin aluminum radiator from the GP and it doesnt have a cap either
Tuesday, January 01, 2008 9:42 PM
maybe its on the bottom? or an internal cap?
Tuesday, January 01, 2008 10:46 PM
I've wrecked enough J-car rads to know there's no cap on the rad, at least on the third gens. There is the 15-psi cap on the reservoir tank.
Tuesday, January 01, 2008 11:32 PM
scott (section8cav) wrote:no matter the engine..there is no radiator cap..just a resevoir cap...i even have the griffin aluminum radiator from the GP and it doesnt have a cap either
I am guessing you haven't worked on a whole lot of vehicles i know for sure my wifes 89 oldsmobile 98 regency brougham has a radiator cap it on the passenger side.
that reminds me what is the best thing to repair the coolant over flow resivor with?
will jb weld hold up to the heat, the pressure or is there some thing better to use?
silicone?
epoxy?
Wednesday, January 02, 2008 11:50 AM
2 part epoxy, its white and black, and becomes silver. wont work on the radiator though. tried that about a month ago and it wont hold the pressure.
Listen F***ers. FASTERTHANAHONDA is a joke because I WORK FOR HONDA. I'll talk @!#$ about Fords to, that doesn't mean I can beat a 12 second mustang.
Wednesday, January 02, 2008 12:11 PM
He was referring to third gen j-bodies
Wednesday, January 02, 2008 12:40 PM
<sigh> this thread FTL
my questions:
1) who sells performance radiators for Jbodies other than griffin in the GP forum?
2) why put a higher pressure cap on your radiator -OR- why put on a "performance" radiator cap? do you plan on raising your water pressure or something..?
3rd gen Jbodies do NOT have a radiator cap
Wednesday, January 02, 2008 3:55 PM
Wednesday, January 02, 2008 4:52 PM
THANK YOU JOHN ! tell ME i havnt worked on alot of cars when HEs the one trying put on a performance radiator cap on a car that doesnt have one *sarcasim*
