complete exhaust minus catback?? - Performance Forum
Sunday, December 30, 2007 12:17 PM
i have an 01 z24 and i had just tried to put a catback exhaust on it but found the flange was too rusted. i was looking into getting headers thinking it has the other half of the exhaust system but it looks like its still missing the midpipe section. does anyone know of a site that sells an everything but catback exhaust? thanks.
Re: complete exhaust minus catback??
Sunday, December 30, 2007 12:24 PM
there is not kit for it. gonna have to have a shop weld some pipe
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
Monday, December 31, 2007 7:47 AM
The part you are wanting is a factory, or stock replacement cat assembly. Very expensive. Advice given by Machzel08 would be cheaper by a long shot. If you are dead set on having a flange, a muffler shop should easily be able to cut the rusty one off and weld a new one on. I would get it welded straight up w/no flange though, less chance for leaks.
Monday, December 31, 2007 9:30 AM
well, if you do it the absolute best way possible you can get the mandrel bent downpipe, high flow cat and some piping done (all 2.5"), welded and installed for around $230.00, give or take.
if you go with crush bent piping and dont mind about size etc. you could probly get it all done for like $75.00
every shop is different though, just check around and ask.
Monday, December 31, 2007 10:07 AM
thanks guys, i'll take it to a shop around here then.
