Any place with a how too?
Forward motion has a tutorial for the bong, im figuring it may start there.
Im going to put in my intake, and i just wanted an idea of what to do, where to look ect.
oi just ripped that sucker out lol i moved the battery and just started pulling lol
Mark wrote:Any place with a how too?
Take out the battery and you will see exactly how it comes out. If you dont have the bong in there still then it should come out pretty easily. If you still have the bong pull the inner fender liner and yank that bitch out think you need to cut a rivet that holds it in. Just look around in there it is really easy to figure out.
Disclaimer:
Dey see me Trollin' Dey hatin' for trollin dey trying to catch me ridin dirty.
i used a hammer....thats it..
cool.....Ill be doing that.
I was looking at it and there seems to be a reservoir for something (it was dark and i couldent tell what it was, attached top the upper part of the air box. do i have to relocate that?
I think you're talking about the clutch reservoir. You'll have to find somewhere else to mount it once the airbox is gone.
Shadowfire wrote:I think you're talking about the clutch reservoir. You'll have to find somewhere else to mount it once the airbox is gone.
I took a thin piece of aluminum... probably 1/2" wide drilled a hole at both sides, bent it into a 90 and bolted one end to the strut tower and zip tied the reservoir to the other end
I hate that there is no edit button because I forgot entirely to write about the airbox... It sounds to me like hes talking about the box on top of the valve cover... but i believe its just the clamp on the TB and hose that runs to the nipple on the valve cover and maybe a screw or two and it pops right off.
I was referring to stock box where the air filter is.
And I looked today, it is the clutch resevoir. I Have a good Idea Where im going to mount it, wish me luck.
AEM makes a nifty aluminum bracket for the clutch reservoir. They market it for the 2.4 5speed cars, but it also works with all 3 versions of the 2.2, including the Ecotec. bought mine for about 30 bucks shipped, it mounts to that bracket the top end of the airbox was attached to. See the engine bay pic in my profile, I think you can see it there.
Up on the upper right, circled in red.
(please pardon the filth, the car and the engine bay are CONSIDERABLY cleaner now)
Thats where i plan to mount it, Im going to make a bracket and A)bolt it on or B)Epoxy it.
That's where I mounted mine as well. Just zip tied it to that small piece.
what is connected to your intake from the top of your engine?
Should I have one of those?
Gah....
crankcase breather tube lol
lol yeah if you've got a 2200 you should probably have it but its not really a big deal if you dont... just makes a mess
