just wondering on how to go about doing a conversion from the DIS on my eco over to actual coils and plug wires. which coils and icm to use? wiring diagrams for it? any help works
check out rodimus's site, is has a walk through how to to swap to MSD coils, wires, and plugs
is there anyway to do it without using msd coils. i mean i eventually wanna run msd but for now i was thinking maybe just use some coils from a 2200 with that icm. will it work?
i suppose it would. but no sense in doing it twice. ya know
yea true but i will get way hotter of spark by running independant coils either way. i just wanted to see if it would work. i'm a gm tech in training and can get oem parts for dirt cheap
Brett Basham wrote:yea true but i will get way hotter of spark by running independant coils either way. i just wanted to see if it would work. i'm a gm tech in training and can get oem parts for dirt cheap
whats your resoning behind thinking coils off a 2200 are going to give you a "way hotter" spark
btw I'm not saying your wrong, just wondering what info you have
because running an independant wire from an independant coil gives it the extra advantage over having one coil run all four plugs. and thanks for the input guys i appreciate it.
