as the title says
04 5-speed eco, stock intake setup, with a K&N drop in filter. Should I even waste my time pulling the bong out or just leave it alone?
Yeah I know this is a total noob question.... I've never fallowed whats going on with gay mods like this (just a drop in rather then an intake) hahahhaah
if your planning on doing the whole intake at some point I would, but if not it doesn't really matter.
Well I preaty much went all out on the silver cav.... this one is just going on my beater/daily driver. I gave a friend a cone filter back in the day so he returned the favro yesterday and gave me a free drop in K&N, I'm not going anywhere near as crazzy with this car, so no no real intake, just sticking with the drop in
Well, call me a dumb@$$, but what the hell is a bong??? (in car terms, that is)
Its the plastic intake tube that is down in the driver side fender.
the "bong" is the intake resonator, located by the driver side front wheel.
all it does pulled out is the engine is slightly louder, no performance increase at all
The people on here are so stupid. Look at the bong tubing it has a pipe that is about 1.8 inches. So your saying a 1.8 inch holes flows just as much as a 2.75 inch hole. Your stupid!!!! Oh and instead of that you could drill a bunch a holes in the air box below the filter to let more air in. It will help a bit!! cya dont listion to these total tool bags who just want to flame every one!! They make this website not so good!
darkblade j
Darkstars, taking the 'bong' off will not only give you some noise, but it WILL let the air enter more smoothly into your intake.  Since you won't have that twisty piece of plastic in there, the air flow will be smoother and easier flowing.  FACT!!!
98 Z24
RIP Specks
you know damn right that it isnt going to gain you more than a half a horsepower, so why waste time posting about it?
I took my bong out, there's a slight growl now from the driver's side fender. Power gains? It seems a little faster right towards the redline but at normal RPM ranges it feels about the same. So I'm guessing it's a 1 hp gain at 5500 rpm. Plus it saves about 5 lbs of weight.
I was happy when I heard my car ran 10s. Then I found out that was 0-60.
remove it.  You'll drop about 5 pounds off the car, all that plastic adds up.  I have a huge bag of all my stock intake parts, weighs a fricken ton I tell you.
-Chris
Like alot have already said, just remove it cause its useless, itll free up some room for air to get thru and itll free up some weight, better than just having it sit there doing nothing.
okay, here's a good question for you guys then....
When I go to the racetrack should I remove my driver side front corner lense?  That would allow considerably more air into the intake bong, I would think.  Also, if I DID remove that turn signal lense to allow air into the fender would it work more to my advantage having the bong to catch the air or NOT having the bong and letting the air just find it's way to the airbox?
"An okay movie is the same as an ex girlfriend...it was good at the time,
but you never want to see it again... especially if the movie was a bitch."
ok yea take it out you will see a difference. or just swiss cheese you air box with a drill bit it help these people are negative. I have adrilled air box with a k and n intake and yes it helps weather you guys say it does or not . I dont have $200 bucks for a peice of tubeing! Try then then unhook your batery for like 1 hr then hook it back up and the computer will adjust just like it would you you pay $200 bucks for an aem !!!!I would recomend gettign a k an n adrop in !!!!
darkblade j
ok , so how long does it take to take the bong out? 10 mins? 15? take it out. c'mon now
2000 Camaro V6.
I took mine out in like 5 minutes but the bumper was already off
I think I may just rig up some kind of ram air.... the beater has no fogs so I might just weld together a sheet metal box behind the drivers fog light, seal it flush against the bumper and run a pipe/tube up to the bottom of the air box, I'll chop the top collor off the bong and attach the piping to that so it will still fit tight to the air box and silicone it in place.
raim air/ cold air intake with stock look and next to no cost involved
This is why doctors will give one person out of five a placebo when testing a new drug. To see if they are imagining some great results that aren't really happening.
Same goes with these theories about opening up the stock intake for wonder increases in raw horsepower. Sure, better flow = more power, in caveman terms.
But the true gains in an aftermarket intake for a Cavilier are not in the filter, but in the tubing. It's not just a 'peice of pipe', look how the stocker flattens out near the throttle body. Tell me that doesn't restrict just a little? The aftermarket units cure that gross engineering blunder. Sure, they're expensive, but there's a reason you spend more for them.
01' Saturn SL2
DOHC 'LLO' automatic
bolt on mods
Darkstars wrote:I think I may just rig up some kind of ram air.... the beater has no fogs so I might just weld together a sheet metal box behind the drivers fog light, seal it flush against the bumper and run a pipe/tube up to the bottom of the air box, I'll chop the top collor off the bong and attach the piping to that so it will still fit tight to the air box and silicone it in place.
or, instead of going through all that trouble......
get a piece of flexible clothes dryer vent hose and use that.  It's lighter than a sheet metal box, costs less for materials, and will take literally 5 minutes to hook up.  Just clamp it to the backside of the foglight hole and to the opening on the airbox.
^^^^ more or less thats what I'm gonna do
and 2001twincam your post relates to this topic how????
