ok just a quick ? when i put my 93 2.3l t/b on i put the stock 2.4l throttle positioner senor on the 2.3 thottle body. is this rite cuz i like dosent have good throttle response no so my ? is can i put the 2.3l throttle positioner sensor on it ?????? and will it still work i was in a hury when i typed this so just please help out thanks paul
as many have said many times run the 2.3 sensors on the 2.3TB run the 2.4 sensors on the 2.4 TB
does that mean with my 2.4 harness and plug it into the 2.3 sensor i mean the harness from the idi cover to the iac and the iat sensor i can use the stock one off my 2.4
? ans plug it in the 2.3l throttle positioner sensor
yeah the 2.4 harness plgs into the sensors fine you do use the 2.4 IAT sensor though that that if it cam eoff the 2.3 motor you should be using whatever sensor is attached to it and vise versa.
k thanks man thats all i needed hey and do you know if haveing the throttle positioner sensor in the wrong position i tryed to mod my stock one like it said to do on ny jbody could cause the car like sputter from a launch ???? or like shifting at high rpm
like i said run the 2.3 sensor and it will work like it is supposed to, the 2.4 harness will still plug up and it will work fine. The person who wrote the nyjbody library entry even came on here and said that the 2.3 sensors would work fine on the 2.4 engine without any problem.
