Pure Petroleum - Performance Forum
Pure Petroleum
Sunday, April 02, 2006 7:17 PM
Has anyone heard of running pure petroleum through an engine in the oil and gas. A buddy of mine with a 2001 Civic said he did it and it was supposed to clean out the entire engine. He said he got it at a local part store. Anyone know anything about this.
Re: Pure Petroleum
Sunday, April 02, 2006 7:57 PM
I've used a product called "Seafoam"... Google it, and you'll find everything you need. I suspect this "Pure Petroleum" is the same kind of top-end cleaner.
Re: Pure Petroleum
Sunday, April 02, 2006 10:56 PM
Matt Archibald wrote:Has anyone heard of running pure petroleum through an engine in the oil and gas. A buddy of mine with a 2001 Civic said he did it and it was supposed to clean out the entire engine. He said he got it at a local part store. Anyone know anything about this.
Lenko, John Lenko wrote:I've used a product called "Seafoam"... Google it, and you'll find everything you need. I suspect this "Pure Petroleum" is the same kind of top-end cleaner.
he talked about running it through the engine and oil itself John, not as an exterior engine cleaning, internal. However I can see why you overlooked that as it sounds simply retarded.
And how would it clean out the entire engine? If you put it in the gas, it could possibly clean a small portion on the intake side of the head, the cylinder walls, and then if there's any gas that didn't burn up, a small fraction could 'clean' the exhaust port side of the head.
Re: Pure Petroleum
Sunday, April 02, 2006 10:58 PM
^^^continued (damn post button)
And if you put it in the oil, it would just recirculate whatever it 'cleaned' throughout the entire engine again.
I think you're buddy with the civic was either lying to you, or you're horrible and remember what ppl tell you...
Re: Pure Petroleum
Monday, April 03, 2006 1:46 AM
I ran it directly trough my intake.... through a port in the TB or any place like that. Pour slowly.
Re: Pure Petroleum
Monday, April 03, 2006 4:13 AM
thats exactly how seafoam works, im sure its basically the same stuff
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Re: Pure Petroleum
Monday, April 03, 2006 6:47 AM
Seafoam goes inside the engine not an external cleaner.
Re: Pure Petroleum
Monday, April 03, 2006 6:56 AM
seafoam...gas tank, throttle body, crankcase...hence...cleaning internals in the process
Re: Pure Petroleum
Monday, April 03, 2006 11:02 AM
No one said anything about external cleaning.... except for cmunn99gt who seems to be a bit off-base here. Ah well.
When I said "top end" cleaning... I mean clean the internal bits. But GM uses some de-carbonizer crap they pour into the cylinders with the plugs out... or so I've been told... I don't trust anyone at the local dealerships to not screw up my car... so...
Re: Pure Petroleum
Monday, April 03, 2006 12:07 PM
I use Seafoam. I put part of it in the fuel tank, part of it in the oil, and then I run part of it through the TB using a vacuum port and a rubber line that i just stick inside the can. It sucks the stuff right into the intake. It runs a little rough for a few minutes but everything gets burned up and sent out the exhaust. It's good stuff. I've used it on every car I've owned, even carb'd motors.
Re: Pure Petroleum
Monday, April 03, 2006 2:16 PM
my bad guys, I'm thinking of simple green, way off
doesn't GM sell something called 'CLEANZ' that you can pour in your engine?
I was thrown for a loop when you said put it in the oil as well. Cant really see anything getting into the oil, and even if something did, thats what oil changes are for. I'm going to go now...
Re: Pure Petroleum
Monday, April 03, 2006 2:34 PM
ln2johnny wrote:I use Seafoam. I put part of it in the fuel tank, part of it in the oil, and then I run part of it through the TB using a vacuum port and a rubber line that i just stick inside the can. It sucks the stuff right into the intake. It runs a little rough for a few minutes but everything gets burned up and sent out the exhaust. It's good stuff. I've used it on every car I've owned, even carb'd motors.
Exactly which vacuum line are you talking about? Pics would be greatly appreciated!
"Eagles may soar, but weasels don't get sucked into jet engines." -- Steven Wright
Re: Pure Petroleum
Monday, April 03, 2006 3:37 PM
cmunn99gt wrote:my bad guys, I'm thinking of simple green, way off
the crankcase is where the oil is...
