Need Help With New Motor Mounts - Performance Forum
Thursday, March 30, 2006 5:43 PM
i just got the Poly Upper Insert and lower dog bone from RKsport, i have no clue on how to get the upper one in, if anyone could help that would be great, pics would be appricated
fully built 2200-TO4E T3/T4-HP tuners-373hp @18psi
Re: Need Help With New Motor Mounts
Thursday, March 30, 2006 5:53 PM
I don't have any pics, but once you take a look under the hood where the mount is, it should become apparent what needs to be done. I think there are four nuts that need to be removed, and then you'll be able to move stuff around and get the insert in there. Be warned, it is a pain in the arse to get in so use plenty of soapy water.
Thursday, March 30, 2006 5:58 PM
ok, well its like having sex for the first time, just got to figure out were to stick it in and make sure its lubed up!
Thursday, March 30, 2006 7:05 PM
Friday, March 31, 2006 4:43 PM
use your jack stand under the engine to hold it in place!!!! the rest is on the site above
Friday, March 31, 2006 8:26 PM
blink 777069 wrote:use your jack stand under the engine to hold it in place!!!! the rest is on the site above
i never did that. mine went in fine
well i got um in, i didnt use a jack either, i did it in a macdonalds parking lot, i like the feel of them but the rattling is kind of annoying
Saturday, April 01, 2006 6:50 AM
did you notice much more rattle from your engine? have you installed both already? I just bought some too, do you have a balanced engine?
