ho manifold fitment issue...cut, yes or no? - Performance Forum
Thursday, March 30, 2006 11:47 AM
Ok so I went to fit the manifold today and its good except that this point that my finger is pointed to gets in the way. I just wanted to check and make sure everyone else had to cut it off cause once I cut it it looks like it will fit fine. The bolt I am talking about is in the first pic. In the second pic it just shows all the wiring, that also kinda got in the way till I took it off that bolt that I need to cut off. What did you guys do to secure all this wiring?
Re: ho manifold fitment issue...cut, yes or no?
Thursday, March 30, 2006 1:50 PM
I cut it and relocated my grounds. That's what I did.
Thursday, March 30, 2006 1:54 PM
actually scratch that.
I cut it SHORTER and left my grounds there I think. it's been a while ><
Thursday, March 30, 2006 3:18 PM
leave the nut on and cut the stud off flush with the top of the nut and it will work.
Thursday, March 30, 2006 3:31 PM
^ Yup, thats what I did.
Thursday, March 30, 2006 4:56 PM
i switched the bottom and the top
Thursday, March 30, 2006 6:37 PM
what do you mean you switched the bottom to the top?
Thursday, March 30, 2006 6:58 PM
sorry to jack the thread but since you guys have the hO mani, anyone got a clip of the engine bay reving? im wondering how it sounds.
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
Thursday, March 30, 2006 7:16 PM
I'll get one tomorrow maybe. ^^^
Thursday, March 30, 2006 7:19 PM
CzapskiKandyKav wrote:what do you mean you switched the bottom to the top?
There should be two bolts the one that is in your way and the one below it. Take out the one below it and put the one that is in your way in that hole. so you switch them.
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
Thursday, March 30, 2006 7:26 PM
Just intake
HO manifold and intake
Thursday, March 30, 2006 7:56 PM
there is a stud and a bolt under it , its about 2" lower on the block
you can kinda seeit in his 2nd pic , its holding up a bracket for the wire loom
Thursday, March 30, 2006 10:02 PM
ok sounds good I'll do that tomorrow..did you put your ground wire from the battery on the lower one too?
Thursday, March 30, 2006 11:02 PM
yes i did
Friday, March 31, 2006 1:30 AM
yep, I just moved it down to the lower hole........ the last one I did, I cut the stud end off..... didnt need it anyway...
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Saturday, April 01, 2006 11:03 AM
Ok so I moved it all to the lower hole and moved the rest of the wires out of the way everything is good there. My next issue is the bottom studs. They sit flush with the manifold when the adapter plate is in place with the manifold. How are you supposed to get a nut on the end of that stud if it doesn't stick out at all?
Saturday, April 01, 2006 11:06 AM
longer bolts or studs
i used longer bolts
