Has anyone seen ore heard of a Cobalt SS motor swaping into an 03 Cavalier Ls can it be done??????????????
Got $20,000? Then do it.
The transmission won't fit (if you search a bit, you'd find this out). You'd have to tube the front end to make it work, and swap over every single wire in the car... because the SS is a drive-by-wire car... no throttle cable.
basically, you're taking a Cobalt SS... and transplanting the entire thing into a Cavalier shell. Not worth it, unless you're loaded and stupid. Just take the SS
just buy the gm eco s/c kit
youll be way better off
and there is a BOOST fourm and search button for a reason
they are right..if you want the cobalt engine then go buy a cobalt..otherwise your basically wasting time and money
[quote=97cavie24ls(JDM&00s/c sedans™)]just buy the gm eco s/c kit
GM Supercharger, Hahn Racecraft turbo kit, or custom turbo. Any of those sound way better, WAAAY cheaper, and a hell of a lot more rewarding. The SS swap would be a gigantic cluster-f**k.
