so im ready to get the 13/32 drill bit and the 12x1.25 tap to re-drill and tap the whole for my knock sensor and im just curious is there a special type of bit and tap that you need to use or do you just use a metal drilling drill bit? thanks alot guys!
anything from someone who has done this?
We used a regular drill bit, as long as the tap is that size you are fine. Also read the info posted in the other post about this as well.
any type of drill bit , just as long as its the right size
and the tap will tell you the size
just go slow
alright guys thanks. yeah another guy on here gave me the sizes for the bit and tap so i should be good to go. thanks again
