Throttle cable tensil str? - Performance Forum
Sunday, March 12, 2006 8:13 PM
Does anybody know the tensil strength of our thottle cables?
I have a DIY thread on a local car club forum, but i want to make sure the new firmer feel of the gas pedal wont over stress the throttle cable.
Re: Throttle cable tensil str?
Sunday, March 12, 2006 8:15 PM
Not much, I snapped one pretty easy
Sunday, March 12, 2006 9:32 PM
I broke one in the past too, but that was from damage to its outer sleeve.
Monday, March 13, 2006 6:06 AM
what are you doing that would stress the cable?
I'm pretty confident it could withstand a good bit of force, braided fishing line of a smaller width can come to 50lb plus, and the throttle cable is made of steel.
-Chris
Monday, March 13, 2006 7:40 AM
the weakest part of the cable is the ends
but id say itll hold close to 100 lbs , depending how hard you floor board the car
but as long as there is no kinks , it should last quite a while
Monday, March 13, 2006 9:11 AM
I would also say the S'ut is going to be close to 150 ish. A jerky force stresses the metal more than you think. Like if you jump you exert more force on the ground when you land than you weight. You have to push it past the tensile point for it to break though.
Yea, ummmm. I used to have a J-body...
Monday, March 13, 2006 8:13 PM
IamRascal wrote:what are you doing that would stress the cable?
http://jbodynyc.jconserv.net/viewtopic.php?t=54
Monday, March 13, 2006 8:24 PM
That might not surpass the tensile strength of cable, but the spring may not handle the added spring rate...
Monday, March 13, 2006 8:39 PM
Well i drive about 120 Miles each day, i have an extra spring, so i guess ill see how long it lasts.
Monday, March 13, 2006 8:46 PM
lol That's one way to test it.
Tuesday, March 14, 2006 7:45 PM
Do you have a better way?
Thursday, March 16, 2006 8:09 PM
Nope, can't think of one. So it's been a couple days, what's the verdict on the pedal feel?
Thursday, March 16, 2006 8:51 PM
still the same, no problems.
Thursday, March 16, 2006 9:25 PM
hows the tb workin out
Thursday, March 16, 2006 10:23 PM
[quote=97cavie24ls(JDM&00s/c sedans™)]hows the tb workin out
ran out of patiance and install time, ill try putting it on again tommorow.
