Luke Heier wrote:I finally got my secret secret cams and plan on installing them in the next few weeks. I am wondering if anyone has any suggestions as to what I should replace while I have the engine ripped apart. Obviously, I am going to replace all gaskets and seals and the tensioner, and all that. I read the suggested parts list. But I am wondering what other things I could change that would be a good idea or give me some benefit.Replacing the lifters is a good idea. I see your car is relatively high-mileage, so that should be a good idea no matter what. It's recommended that you do them at the same time anyway. Other than going through GM or another auto parts store, the only performance lifters I know of are made by JBP, but they are pretty expensive at $340 US, and have a REQUIRED core charge of $71 US. Plus, nowadays they won't send you your new lifters (or anything else with a core charge, for that matter) until you send them your old ones
I plan on changing the water pump since I have just over 100,000 miles on the original. I read that it is fairly easy to change if you are doing the cams at the same time.
Any other engine internals that I could change that would be of benefit and are fairly inexpensive (in the few hundred dollar range)? I was thinking possibly valve springs??
Thanks in advance for any replies.
