Silly question I know, But can the portd be cleaned with the head still on the car? Just to remove all the buildup in there.
I took a spatula and cleaned off what I could,
Seafoam for when the car is in operation.
other than that I'm not sure.
Inari wrote:Seafoam
1/3 in the intake
1/3 in the crankcase
1/3 in the fuel tank
It gives you the equivelant of what a shop charges you $60.00, its $5.43 down here for a can.
-Chris
I would just pull it off, if you have build up in the intake and exhaust ports then you have build up on the pistons and and the combustion chambers of the head
if its for the eco motor your gonna put in your cav wait tell its running
[quote=97cavie24ls(JDM&00s/c sedans�)]if its for the eco motor your gonna put in your cav wait tell its running
yup, sounds like good advice.
i just wanna add that seafoa, is some meraculous stuff. put it in, let it sit, watch all that smoke shoot out the back of the car when you start it back up. ummmmm clean piston heads
what happened to the 2200 build??
an eco landed in my garage
very sexy sig..esp with that pacesetter header on.
