good glasspack? - Performance Forum
good glasspack?
Wednesday, February 01, 2006 3:42 PM
currently have a pacesetter exhaust and pacesetter header after market cat and I'm not liking the sound of my exhaust its not deep what so ever. I asked around and everyone is saying it a cherry bomb , glass pack, resonator. what brand do you guys think I should go with?
Re: good glasspack?
Wednesday, February 01, 2006 3:54 PM
http://www.j-body.org/forums/read.php?f=2&i=341591&t=341591
sounds like Dynomax is the way to go.
Desert Tuners
Re: good glasspack?
Wednesday, February 01, 2006 5:19 PM
LOL WTF is going on today!??! This is like the 4th thread in the Performance Forum since noon where people are asking what resonator or glasspack they should use!! My fingers are sore from so much conversation about this topic, I'll make it brief.
Dynomax Thrush Magnum, summitracing.com
Re: good glasspack?
Thursday, February 02, 2006 8:51 AM
Additionally, you're gonna have to basically what I'm doing to my Pacesetter cat-back. The glasspack I put on there got rid of some of the raspiness, quieted it down just a little, and kinda gave it a slightly deeper sound. So the glasspack did wonders, but the big weakness of the Pacesetter system is the horible muffler. I mean that thing sucks. Eventually you're gonna want to get a new muffler on there to actually pull deep smooth tones.
Re: good glasspack?
Thursday, February 02, 2006 3:36 PM
i'm putting the glass-pack after my cat then i'm just going to rub a pipe back
Re: good glasspack?
Thursday, February 02, 2006 4:51 PM
Go with the dynomax, can't beat it for the price.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Re: good glasspack?
Thursday, February 02, 2006 5:23 PM
im 100% pleased with my 24" cherrybomb for $20
The one, the only, ME.
Re: good glasspack?
Friday, February 03, 2006 11:59 AM
so you guys that are running 24" and 25" glasspacks... are you running cats too? I've got my pacesetter cat to muffler piping laid out, and there's no way it's gonna fit a glasspack that big.
Desert Tuners
Re: good glasspack?
Friday, February 03, 2006 1:45 PM
Yep, 16" long cat and 25" resonator. It fits with room to spare.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Re: good glasspack?
Friday, February 03, 2006 2:07 PM
Z24 FReQ (Jarett) wrote:so you guys that are running 24" and 25" glasspacks... are you running cats too? I've got my pacesetter cat to muffler piping laid out, and there's no way it's gonna fit a glasspack that big.
Actually, I have the Pacesetter System too, and I'm running a 25" glasspack on it right behind the flange, and yes, there's plenty of room to a cat. Believe me, they both fit The length on the unit overall is 25" (tip to tip), but the length of the casing (the actual glasspack part) is 20" long. You've got a 2.5" tip on each end, so you've got an extra 5" to play with. I opted to remove 1.25" from each tip (making it a 22.5" overall length), just to make things easier. It's not necessary, but at least I knew I could take advantage of ONLY THE STRAIGHT section of pipe on the Pacesetter system, but even then it's not necessary. However, if for some odd reason you're clamping this glasspack on instead of welding, you might not want to shave any length off the ends so you can slip it far over the Pacesetter piping to get the best seal possible.
Don't quote me on this, but before I bought the glasspack, I crawled under the car with a tapemeasure, and from 1/2" past the flange to 1/2" before the first bend, I came up with a total of like 27-28" of useful straight pipe to mount the glasspack to. Plenty of room.
Re: good glasspack?
Friday, February 03, 2006 2:47 PM
that's what I was thinking, was welding a flange on the resonator to bolt up to the Magnaflow cat, and that should be enough room to weld the other end of the resonator right up before the bend. if need be, an inch or so could be cut from the ends of the resonator so it'll fit right.
Desert Tuners
Re: good glasspack?
Friday, February 03, 2006 2:54 PM
Z24 FReQ (Jarett) wrote:that's what I was thinking, was welding a flange on the resonator to bolt up to the Magnaflow cat, and that should be enough room to weld the other end of the resonator right up before the bend. if need be, an inch or so could be cut from the ends of the resonator so it'll fit right.
That'll do just fine.
Re: good glasspack?
Friday, February 03, 2006 5:08 PM
it fits with ease i welded my cat to the down pipe and then used a coupler between the 14" cat and 24" glasspack and there plenty of room after the glass pack heres a pic if youd like
Re: good glasspack?
Friday, February 03, 2006 6:27 PM
Event had a 30 inch glasspack under his car,
So yeah you can get ones that are pretty long.
And that IS what 'she' said.
-M
Re: good glasspack?
Friday, February 03, 2006 7:52 PM
Heck, I've got a 35" glasspack, but I've got the 2.2L.The exhast manifold or header exits the motor from the front. Just moved the cat forward about 8" and it fit. I also used some pre-bent pipes.
