water temp set up - Performance Forum
water temp set up
Wednesday, February 01, 2006 7:08 AM
would it work if i drilled and tapped my coolant reservoir for my water temp gauge? or is that not accurate enuff and i would need somewhere directly into the engine
if not then wut would a good place on a 2.4 be, i bought a gauge kit and it comes with one so im gonna use it...
one other question would be, the temps on the gauge start at 130..is this way to high if i were to tap my intake pipe to get a IAT?
its got a temp sensor it should be able to measure any temperatures rite?
Re: water temp set up
Wednesday, February 01, 2006 5:46 PM
nobody knows if this would work?
