ok I just have a quick question about autometers electric oil pressure gauge. I just wanted to know if theres a oil sending unit that comes with it cause all it tells me like on ebay or autometers website it comes with npt fittings and harness. I just wanna know before i go and pick one up and I need more parts. I already know that i need fittings to hook it up with the stock oil sensor.
Well I have the Faze oil pressure gauge and it came with everything I needed and more. It had a bunch of fitting for all types. Since autometer is of a higher qaulity than Faze I believe it should include everything you need with the kit.
If you order from ebay or a person I would make sure. But if you get it from a retailer it should..
http://registry.gmenthusiast.com/images/importkilla32/Bullit.JPG
Z Speed Cavi wrote:ok I just have a quick question about autometers electric oil pressure gauge. I just wanted to know if theres a oil sending unit that comes with it cause all it tells me like on ebay or autometers website it comes with npt fittings and harness. I just wanna know before i go and pick one up and I need more parts. I already know that i need fittings to hook it up with the stock oil sensor.
Why not just ask the person you are buying from?
its its a new electrical gauge, it'll come with the sending unit. mechanical would only come with the fittings and nylon line. ask the seller if you're uncertain
I've got the Autometer SportComp electric oil pres. gauge, and yes it comes with the sending unit and npt fittings. Everything you need to hook it up, minus some 16 gauge wire.
