Can Someone please give me a step-by-step on how to get the GD bong/washer fluid holder out of that fenderwell? I have looked at tutorials that say, "Oh just take out that 10mm bolt and pull the thing out." IT"S NOT THAT EASY... I pulled the headlight out and found yet another bolt that needed to be removed... how many are there on 03+ Cavaliers and where are they? Please... My car is in pieces on the driveway... I bought the intake used so I didn't have a manual.
Thanks in advance.
AEM Install
Thats the best i can do man. I dont exactly remember how many bolts there are but unless you take off the wheel it is a PITA.
~Riki
SPONSORED BY: No one!
Car Domain Site
Riki Knight wrote:AEM Install
wish I had this when I installed mine
great info
well... I didn't have a jack so I was doing it without removing the wheel which was a ROYAL PITA as mentioned above... but I did get it in finally and it's pretty nice. For clarification, it's 3 bolts total to remove the intake resonator/washer fluid reservoir assembly. THREE... one will be visible from the wheel well after removing the fender liner, the other two will almost REQUIRE you to remove your headlamp assembly. One will be right behind the driver's side headlamp, while the other will be tucked in a corner just above the bottom of the bumper on the bottom of the resonator assembly towards teh front of the car.
You don't need to remove your headlight, just jack up the car and you can get to everything. I'd reccomend a ratched with an extender for some of them. For those that don't have a jack, all cars come with one in the trunk, and always use jackstands when working under a car
-Chris
Did you not order the true AEM cold Air intake? Mine came with directions on how to install it.
yeah, bought used... no instructions...
I just did what everyone else has suggeted, jack the car up and take the inner wheel well liner out or just enough so you can move it out of the way. It is actually a fairly easy install, but you don't need to take the headlight out.
didnt your car come with a jack?
Yes I have a jack, but no jack stands... generally not a good idea to work under a car just using the stock factory jack... I wouldn't trust it... I didn't word it right, though, had I had jackstands, I'd have used them.
It was by no means an easy install for me. Once I got the fender well out, I had to move the winshield wiper fluid resevoir, pain in the you know what, and then there was some bold (10mm) I couldn't even find. I was sooooooo mad for 30 minutes or so until I found that tiny bolt. Look in the most retarded place and you'll find it, I think.
