Yayy more Arospeed header problems :( - Performance Forum
Monday, October 31, 2005 4:00 PM
Gosh this is really a crappy design. First of all the connection between my cat was banging against each other so I cut a little notch outta the subframe.. then it started sounding like I had an exhuast leak everytime I gave it throttle
It was still rubbing on my subframe connector on the top, so I cut out a notch on the top, it helped with some of the sound and it was good to at least not have it rubbing on everything .
But now the downpipe is resting right on top of my P/S lines everytime I give it thottle and my motor mounts give way..
So now once again I ask the board if they have any solutions.. maybe something thin that will not melt from the heat and also stop the terrible sound
Re: Yayy more Arospeed header problems :(
Monday, October 31, 2005 5:04 PM
I knew that thing was to good to be true. You get what you pay for, Sorry you ran into problems tho.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Monday, October 31, 2005 5:07 PM
Fire Fighter wrote:I knew that thing was to good to be true. You get what you pay for, Sorry you ran into problems tho.
well others had no problem, I just don't know wtf makes my car so different
Monday, October 31, 2005 5:09 PM
deffinatly get that off the p/s lines asap!! that is very flamable, i remember a lil while back someones turbo downpiping was near there p/s lines and it burned his whole engine bay.
Monday, October 31, 2005 5:18 PM
ACav2Envy wrote:deffinatly get that off the p/s lines asap!! that is very flamable, i remember a lil while back someones turbo downpiping was near there p/s lines and it burned his whole engine bay.
they arent coated with that plastic stuff...but I strongly agree i need to do something..
Monday, October 31, 2005 10:09 PM
anybody think header wrap could help>?
Monday, October 31, 2005 10:15 PM
take the header out
it's apparently a pile of shat and you're telling us that
replace it with something worthwhile
and i tell you what, i NEVER would've notched the subframe NEVER.... i would've asked for my money back
Monday, October 31, 2005 10:17 PM
L33tJbody (Brandon Gathye) wrote:anybody think header wrap could help>?
Header wrap could be even worse of an idea because moisture could get inside of it and rust the header out.
If I were you, I'd cut my losses and sell it on ebay or classifieds and try and get some money back for it OR you could just throw it away and buy a more known (popular) and quality header. Spending your money trying to fix it won't help at all because you'll more than likely have problems with it in the future as well.
Sorry for the crappy results. Good luck bro.
Monday, October 31, 2005 10:25 PM
meh i'll just buy motor mounts and be done with it..just looking for a temporary solution till then
Monday, October 31, 2005 11:00 PM
L33tJbody (Brandon Gathye) wrote:meh i'll just buy motor mounts and be done with it..just looking for a temporary solution till then
I guess so. I mean, if you leave it on it might cause more problems in the future. Eithe way, good luck.
Tuesday, November 01, 2005 1:37 PM
I didn't have any problems with mine.
Make sure its on their good and tight.
If you have an exhaust leak take it to a ship and have them,
1.) hit the bolts a few times with an impact.
2.) get the cat welded to the downpipe.
-Chris
Tuesday, November 01, 2005 6:21 PM
Everything Is tight its just the stock motor mounts are wayy to mushy and move under any throttle..The DP is already welded to the cat
