Cold Air intake - Performance Forum
Cold Air intake
Monday, October 31, 2005 6:58 AM
Hey I just bought a cold air intake and I am fairly new to moding cars but I was just wondering if there is anything else I need to install the intake as far mounting or sensors, etc. any help would be much apprieciated.
Re: Cold Air intake
Monday, October 31, 2005 7:06 AM
If Its a true cold air intake just make sure you have a water bypass valve cause nothing sucks worse then sucking water into the engine.
Good Luck
Re: Cold Air intake
Monday, October 31, 2005 3:01 PM
Jackalope wrote:If Its a true cold air intake just make sure you have a water bypass valve cause nothing sucks worse then sucking water into the engine.
Good Luck
Don't bother with what he said, some people like to go mudding in the swamp, for all the rest of us, theres no need for the bypass.
All you need to hook up is your VAC sensor, and your IAT sensor, typically, both run into the intake tube, but I dont know what intake you got because you didnt fill out your registry, so it might not in your case.
Re: Cold Air intake
Monday, October 31, 2005 5:23 PM
The reason I saod that was if you run thru a big ass puddle. Around here some of the roads tend to go under water when it rains hard so I was only recomending insurence thats all. This is the reason I don't have one. If you don't have a big puddle problem where you are then you shouldn't need it. But I always tend to go the BETTER SAFE THEN SORRY route but thats just me. OH and dont go thru and mud holes!
Re: Cold Air intake
Monday, October 31, 2005 5:29 PM
well i personally dont have a bypass valve and have driven through several heavy rain storms and have had no probs.. i have the step by step instructions with pictures that i got w/ my AEM CAI if u would like me 2 e-mail it 2 ya!! the instructions helped out a lot tellin me where every bolt was an stuff ....but mine is for the 03-05 ecotec..go luck!
Re: Cold Air intake
Tuesday, November 01, 2005 6:33 PM
Does anyone know were to buy a water bypass valve
Re: Cold Air intake
Wednesday, November 02, 2005 6:55 AM
Check your local tuner shops they can probly help you out. Or go on line.
Good luck
Re: Cold Air intake
Wednesday, November 02, 2005 7:34 AM
k jones wrote:Does anyone know were to buy a water bypass valve
AEM is the only company to trust for a bypass valve, if you want one to work properly. My air filter is less than 6" from the ground and I've never had any problems driving through heavy storms... and I don't have one.
Re: Cold Air intake
Wednesday, November 02, 2005 8:09 PM
ditto
Re: Cold Air intake
Wednesday, November 09, 2005 3:44 PM
When you but your cold air intake on did you have put it in from under the car?
Re: Cold Air intake
Wednesday, November 09, 2005 4:31 PM
I have the bypass just because I feel it's better to be safe than sorry. If you have an AEM CAI, then chances are you'll need the 2.75" bypass
And if I remember, I never jacked up my car when I installed my CAI... just turned the wheels all the way to the left
Re: Cold Air intake
Wednesday, November 09, 2005 4:38 PM
I had the Bypass and it's Sh!t- The foam surrounding litterally deteriorates to nothing in 2 months right down to the rubber- Save your $50 and put it towards a Header or motor mounts.
Re: Cold Air intake
Wednesday, November 09, 2005 5:11 PM
Well, I've only had my intake on for a month, but no problems what so ever with the bypass... maybe you got a bad one
Re: Cold Air intake
Wednesday, November 09, 2005 5:43 PM
How did you get yours in I cannot seem to get it in. I have my wheels turned all the way to the left and still cannot get it. Did you guys struggle with it?
Re: Cold Air intake
Wednesday, November 09, 2005 5:49 PM
Did you put it in from the bottom?
Re: Cold Air intake
Wednesday, November 09, 2005 6:36 PM
I followed the instructions that came with mine... basically remove the wheel well liner, remove the bong (snake looking thing), remove battery, move fuse box out of the way, remove stock air box fight with metal tube to get it in right, connect to the plastic pipe from the TB using the bypass valve or rubber cuppler then attach the filter. Then replace the Clutch resivour (use zip ties or spend $20 for the AEM bracket), fusebox, battery and wheel well liner.
Drive car
That's about it... now this was the 1st CAI that I installed, and it took me about 2 hours (yeah, I'm slow). But with my old car, it took me 20 minutes to install the K&N Typhoon.
Re: Cold Air intake
Wednesday, November 09, 2005 6:40 PM
thnx bro helps out so much serious.
Re: Cold Air intake
Thursday, November 10, 2005 2:53 PM
Could anyone with a 96 z24 e-mail me the instructions to install the cai
Re: Cold Air intake
Thursday, November 10, 2005 3:30 PM
What kind of cai is it? What's the brand name, or is it a ebay special? Knowing what it is would help us. It should just bolt right in though, where your stock unit is.
Re: Cold Air intake
Thursday, November 10, 2005 3:52 PM
It is aem the guy took it out of his car but could not find the instructions.
