What are you trying to get, 5 more HP? Freakin' Newbie
No, I don't know any places...sorry
lol i would assume this is for your subs and electronics and other audio equipment
Tyler Lemburg wrote:http://verizonsupersite.com/4alterstartcom/pages/store/skudetail.nhtml?profile=highoutputalternators&uid=10108&returnURL=http%3A//verizonsupersite.com/4alterstartcom/pages/common/sitese
arch.nhtml%3Fquery%3Dcavalier&catuid=10013
That one is not for the ecotec, all tho, I wish they did make one for it because I used one of their for my camaro.
big daddy wrote:http://www.jbodyperformance.com/new/PartDetails.php?partId=614&catId=614&catName=JP0614&genName=
ask and you shall recieve
I would stay away from this one too because it uses a smaller pulley to make more power at idle, you could do the with the stock one and that pulley. A true high output alt makes what its rated at, at idle. My camaro's alt was rated at 105 max and it did like 37 at idle, my h/o was rated at 180 and did 180 at idle.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
You can go to Mr.Alternator.com he did a few alternators for me. They have really good Customer Service. Email them and tell him exactly what you need. I recently got a 220 amp for a focus and powdercoated it was excelent I couldn't ask for better. It's holding up my 6000 watt Audiobahn setup.
Iraggi Alt. makes one for us. iirc they go up to 250a max. i have a 180a max 120a idle and it works like a charm. pita to install tho.....damn gm puts the coolant right above the alt....
The alt for L61 (2.2) is 105 Amps.
The alt for LSJ(2.0SC) is 140 Amps.
The alt for LE5 (2.4vvt) is 115 Amps
The connector pins for L61 & LSJ are opposite from each other. I'm not sure of the pin connectors for the LE5. Not sure if that helps any.
