ok first i would like to say...i did some searches...but i couldnt really get what i was aiming at...maybe i wasnt doin it right or sumthin...so forgive me for being the "aggrivating noob"
I am going to soon start building up my engine..i have the 2.4L and i was originally going to go with the boost, but then i always found more interest and excitement in the N/A route...but not many people go that way with tuner cars...so i know absolutely pretty much nothing. I do know however..that you aim for higher displacement and compression ratios. I might be wrong on this but on most muscle, v8, or w/e you call them you bore and stroke...i am not 100% on what EXACTLY that does...ups displacement right? makes cylinders larger or something like that?... well my question is can you do that to the 2.4 and if so how large can you go?
i had another question, because i was reading in other forums and random threads and such that many cavy owners were using camaro, and corvette parts. I understand that the computer has to read all of these parts and such..but is it possible if you are going for the n/a route could you possibly use certain parts off those cars?
i appreciate any help you guys are willing to give..and if i am going to build this new motor where should i start?
...are you trolls that dumb that you cant realize mid 15s is slower then 14s?
you bore out the 2.4 or any engine. most go .20 overbore. i wouldnt go any higher than that
and if you rise the compression too much, you have to use race gas in it
Most people don't go the NA route because there's not enough engine to start with. You shouldn't go more than .040" over, and a stroker crank isn't available (you'd be looking at about $2000 to have one made...forged of course.)
You won't be able to use any of the V8 parts because you have a DOHC engine, so nothing is interchangeable.
If you insist on going "NA", maybe think about some nitrous, as you can use it on an engine built "NA" (and in the end, you're going to want it).
Definately look into some cams and some head work, as that's where the power lies in these little engines. Also, try to reduce weight wherever possible. You can swap to a 2.3L oil pump which will give you better lubrication, as well as rid you of the balance shaft (run a search for more info). That's basically the extent of my knowledge on the DOHC engines...
fortune cookie say:
yea i knew about the cams and head work...my main questions were just on like maximum boring and using the other parts..and compression...which i gathered 10.5:1 is what most of you recommend...but has anyone put a daly driver higher than that on an LD9 with out major problems?
I doubt anyone around here is even running around with 10.5:1. All I've heard of is 10:1 on an LD9
fortune cookie say:
find Karos mod list and do that...
Darkstars wrote:find Karos mod list and do that...
I hope he doesn't plan on driving it on the street
fortune cookie say:
just a suggestion...maybe think about swaping heads and getting the quad 086 head fitted on..get forged internals..raise the compression a bit..a good PnP....loose as much weight on the engine as you can.
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
Rob, just reach me on AIM if you need help.
^^ lol...i feel kinda bad for askin you all those questions all the time...i kinda figured it frustrates you a bit...so i decided to give you little bit of a break.
Rob Silvera wrote:^^ lol...i feel kinda bad for askin you all those questions all the time...i kinda figured it frustrates you a bit...so i decided to give you little bit of a break.
No, you don't bother me what so ever.
awesome...yall is greatness
OHV notec wrote:Darkstars wrote:find Karos mod list and do that...
Karo's engine is perfectly streetable. I designed it for street use in his Sunfire. He decided afterward to turn the into a drag only car. But the engine is still the same, except for his lack of decent mufflers.
sig not found
protomec wrote:OHV notec wrote:Darkstars wrote:find Karos mod list and do that...
Well, when he said 'mod list,' I assumed he was talking about everything. Karo's engine isn't even close to un-streetable I know. I was actually surprised when I realized that's all he was putting in the car though...
fortune cookie say:
Karo's mods
Engine Modifications:
2.3 HO Ported Intake Manifold
Accell 92-96 Corvette LT1 Adjustable Fuel Pressure Regulator
Apexi Super AFC
ARP Head Studs
ARP Main Studs
Blueprinted Engine
Balanced Engine
Car Customs Upper Engine Mount Insert
Car Customs Lower Engine Mount
Car Customs Stainless Steel Competition Intake Valves
Car Customs Stainless Steel Competition Exhaust Valves
Car Customs Competition Valve Springs
Car Customs 75mm Throttle Body
Car Customs 4 Inch Race Intake System
Car Customs 4-1 Header 1 Ύ Inch Primaries 3 Inch Down Pipe
Clevite 77 Rod Bearings
Clevite 77 Main Bearings
Eagle Forged Connecting Rods
Holley 255 LHP High Output Fuel Pump
Miller Performance Port & Polish Head
Miller Performance Gear Driven Oil Pump
Miller Performance 2.4L LD9 Competition Crank
Miller Performance 75mm Throttle Body Flange
Miller Performance Competition Oil Pan
Miller Performance Crank Gear
Miller Performance Competition Prep Block
Miller Performance Competition Intake Cam
Miller Performance Competition Exhaust Cam
Miller Performance Exhaust Lifters
Miller Performance Intake Lifters
Miller Performance Exhaust Cam Tower
Miller Performance Intake Cam Tower
MSD DIS II Programmable
NGK TR6 Spark Plugs
ORinged Block
OBD-1 Computer Conversion
W41 Racing Chip
RC Engineering 320cc Injectors
SCE Gaskets Copper Head Gasket .060 Thick
SPEC Custom Competition Clutch Kit
SPEC 8.8 LBS Billet Aluminum Flywheel
Unorthodox Crank Pulley
Venom Fuel Rail
Wiseco 10.5:1 Compression Forged Pistons
Wiseco 91mm Piston Rings
Wiseco Chrome-Moly Wrist Pins
Transmission Modifications:
B&M Racing Short Throw Shifter
Cryo-Treated Gears
Cryo-Treated Transmission Case
Drive Shaft Shop Stage II Axles
Miller Performance Built Racing Transmission
Quaife Limited Slip Deferential
Suspension Modifications:
ARP Competition Wheel Studs
Car Customs Sub Frame Brace
Car Customs Control Arm Bushing
Car Customs Rear Strut Tower Brace
Ground Control Custom Rear Coil Over System
Ground Control Custom Front Coil Over System
Koni Reds Custom Drag Racing Front Struts
Koni Reds Custom Drag Racing Rear Shocks
Polyurethane Front End Link Bushings
Polyurethane Rear End Link Bushings
Monro Front Strut Mount
Monro Rear Strut Mount
Brake Modifications:
Power Stop Cross Drilled Front Rotors
Power Stop Extreme Performance Front Brake Pads
Wheels:
Bogart Front Racing Rims 15x8
Bogart Rear Racing Rims 15x3.5
Mickey Thompson Racing Slicks 24.5x8x15
Mickey Thompson Racing Skinny Slicks 25x4x15
Interior Modifications:
Autometer Phantom 2 1/16 Oil Pressure Gauge
Autometer Phantom 2 1/16 Nitrous Pressure Gauge
Autometer Phantom 2 1/16 Exhaust Temperature Gauge
Autometer Phantom 2 1/16 Fuel Pressure Guage
Auto Power Roll Cage Camera Mount
Bullet Fabrication NHRA Legal Chromeoly 6 Point Bar
LoTek 3 Gauge A Piller
RCI 5 Point Cam Lock Harness
Sparco Pro 2000 Driver Racing Seat
Exterior Modifications:
Aerogear Predator 6 Vent Fiberglass Hood
Car Customs Lexan Driver Side Window
Car Customs Laxan Passenger Size Window
Spyder Automotive Fiberglass Truck Lid
Not for the newbies
Gilles
2.3 Ho
^^wow...thankx
