High compressoion - Performance Forum
High compressoion
Monday, October 10, 2005 11:34 PM
i wanna do an all motor 1999 z24, i was wondering what is the highest and safest compression i can go with and what would be the difference if i were to bore it 20 over, like power and gas mileage?????
Also is it true that u can take a 2.3 block and take your stock 2.4 crank and place it in ur 2.3 block and make it a 2.5????? what is the power gains with this and everything..??????
Thanks alot for your help
Re: High compressoion
Tuesday, October 11, 2005 10:00 AM
i wouldn't go over 10.5:1 compression, from my understanding the PCM won't understand too much over that. Now, boring .20 over would be about the max I would go
Tuesday, October 11, 2005 10:20 AM
Do you mean 0.020 over or actually 0.20 over? For the bore that is.
Wednesday, October 12, 2005 2:50 PM
You can go up to .040 over without ANY problems.
As for the 2.5L engine, it's alot harder than you think. You need to modify the Mains and the block, get customs pistons and bunch of other small things that I won't say.
compression? 15:1 is safe. Tunning is what make it safe. The Ecm doesn't see compression, it see knock that come from high compression when it's not well tune.
you can run 20:1 compression with the stock ecm and not have any problem.
Gilles
2.3 Ho
Wednesday, October 12, 2005 4:56 PM
Mfk-223 wrote:You can go up to .040 over without ANY problems.
Agreed!
You can go .040 over with no problems, my motor is proof.
As fas as compression goes, you should be bale to go 10.5:1 or maybe even 11:1 on 93 octane gas without pulling timing but don't quote me on that.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Wednesday, October 12, 2005 5:06 PM
11:1 on the LD9 with 93 octane is safe. 11.5:1 on a 2.3 with 93 octane.
Gilles
2.3 Ho
Wednesday, October 12, 2005 5:37 PM
listening
