Hey guys. I am planning on buying the Rk Sport dual cat-back exhaust setup (
See it here). I am buying this cause I like the look and I want dual, I will change this out when I eventually get turbo. Anyway, I was wondering if there was any way to rig up a resonator to this setup. Everyone says a resonator is worth getting, so I guess it wont cut the power gain much, will just make the exhaust sound better. Anway, I was just wondering if you could rig it up to this setup, cause I was thinking you couldnt since this setup is a cat-back bolt on. Specifically for the Cavalier. So could someone help me out??
you probably could rig it up, and that cat back is 2.5in piping, so pending on how much boost u run, that cat back should be fine until u start putting down some serious psi
