i need a FPR - Performance Forum
i need a FPR
Wednesday, September 28, 2005 1:40 PM
my fuel presssure regulator is leaking on my 01' 2.4 and i would like to get an adjustable one. where could i get a good one for a reasonable price. thanks for your help
Re: i need a FPR
Wednesday, September 28, 2005 3:49 PM
you could proably just put new O rings in and fix the leak. What mods do you have that you think you need more fuel pressure?
<img src="http://www.saskjbody.org/iB_sjc/uploads/post-9-45611-matt_pt.2_2.jpg"/>
Saskjbody president
Re: i need a FPR
Wednesday, September 28, 2005 4:07 PM
a few of the companies listed in the FAQ have em, like rksport for example...
Re: i need a FPR
Wednesday, September 28, 2005 4:13 PM
Accel 74565 from Summit is $97.
The lower o-ring is replaceable, the upper o-ring is only sold in a new FPR kit from GM.
Re: i need a FPR
Thursday, September 29, 2005 8:50 AM
Just buy the MR universal one for like 40 dollars. Simple as that.
I'll have a sig someday....................
Re: i need a FPR
Thursday, September 29, 2005 1:17 PM
I checked a price on a repacement and its $80 so i thought i would just get an adjustable one. Most of them are cheaper and better. i believe that its leaking from the top where it connects to the rail.
Re: i need a FPR
Thursday, September 29, 2005 1:39 PM
Or you could go to a junkyard and pull one, and use the O rings... Or take it apart, and find out which O rings you need, and go get them from a hardware store. It will be less than $3.00 probably. There are 3, iirc.
Saskjbody president
Re: i need a FPR
Thursday, September 29, 2005 5:29 PM
mattf wrote:Or you could go to a junkyard and pull one, and use the O rings... Or take it apart, and find out which O rings you need, and go get them from a hardware store. It will be less than $3.00 probably. There are 3, iirc.
The only problem with that is they aren't impervious to fuel. So, put them in and they gradually disintegrate.
Re: i need a FPR
Thursday, September 29, 2005 8:54 PM
or you can go to autozone if you got one close to you and by the O rings bc I had to buy 2 new ones and it only cost me a buck to get them.
Go Check Out My Z26 Message Board @ http://v6z26.proboards12.com/index.cgi and tell me what you think Thanks
Re: i need a FPR
Friday, September 30, 2005 5:27 AM
Is that one from Summit adjustable?
Re: i need a FPR
Friday, September 30, 2005 8:28 AM
Yup... the Accel 74565 is an adjustable unit... meant for LT1s but it also works for us. I have one sitting at a store here since my Casper AFPR was totally f*cked (leaked like a fountain randomly and didnt behave correctly)
Dont get a universal FPR... you'll spend more in fittings and @!#$ than you did to make the the thing work in the first place.
