RPM redline on a built ecotec - Performance Forum
Monday, September 26, 2005 7:05 PM
K im getting ready to build a ecotec for big boost, im gonna stick with the stock crank for now and just get it balanced. I'm going with eagle h beam rods, wiesco 8.9:1 Pistons and some better valves and valve springs. I'm also running a emanage with all the add ons. I was just wondering what kind of rpm's this setup can handle or what else I can do to make it friggin scream.
Re: RPM redline on a built ecotec
Monday, September 26, 2005 7:14 PM
listening...
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
Monday, September 26, 2005 7:19 PM
eco build book says with new new valve springs, you can rev it to 7500rpms.
Monday, September 26, 2005 7:20 PM
oops... forgot to add.... you'll need to get the rev limiter removed.
Monday, September 26, 2005 7:39 PM
i've personally heard the stock valve train can handle 7000 but it honestly all matters where your power band is theres no sence in reving past your peak HP, so just remove the limiter when you can and then run it on the dyno and see where your peak HP is and set your RPM limiter to just a few hundred past that
The one, the only, ME.
Monday, September 26, 2005 7:41 PM
Jeff, if the crank is going to be balanced, that opens up a whole new ball game.
get the Titanium Valves and Springs, coupled with the balanced crank, and you' wont have any trouble hitting the higher RPM's
Monday, September 26, 2005 7:43 PM
yeah power stops dropping off at about 5600-5900 rpms. With boost, test it on a dyno and see where you should put the redline. But I would suggest you keep you power within 6500 rpms.
Borsty wrote:Bio:------------- i work at ups lifting heavy @!#$ ill day, and i rip phonebooks in half
Monday, September 26, 2005 8:09 PM
im pretty sure at 20 psi and dyno tuned it can put some pretty good hp at the higher end, and hey steve hows the engine coming along for ya. Dude i totally want to be there when you do the swap.
Monday, September 26, 2005 8:29 PM
You might have a better change of getting things to work with the Megasquirt than the E-manage. My friend is already having enough trouble with fuel and it fighting with the computer on about 7 psi.
Monday, September 26, 2005 8:32 PM
Is he actually doing it himself or is he getting it tuned by someone? Im gonna hand it over to the nerds on this one.
Monday, September 26, 2005 8:37 PM
Jeff Marmus wrote:Is he actually doing it himself or is he getting it tuned by someone? Im gonna hand it over to the nerds on this one.
If you try to tune it yourself, you won't get anywhere without a wideband.
Monday, September 26, 2005 8:43 PM
No I am aware of that thats why I'm going to get someone else to tune it with a dyno
Tuesday, September 27, 2005 4:18 PM
engine's going slow, actually its stopped for a couple months, but I'll be back on track in no time.
Jeff, get a standalone, and you can get rid of that stupid rev limiter... just be sure the crank is balanced
Tuesday, September 27, 2005 5:07 PM
plus if you can run that high rpms you can use a bigger turbo if you want your gains to be at the high end of the rpms
Tuesday, September 27, 2005 6:22 PM
Don't forget to sleeve your block if you're going to be running a lot of boost. I intend to run up to 30psi after I upgrade my crankshaft. Before that, I will run 20psi or a little more at the track and 15psi on the street. Good luck on increasing your RPM's and good luck getting any real use out of it too. I thought about increasing my RPM range, but there's no real point as of now (at least for me). Also don't forget about getting water injection. It helps boosted cars TREMENDOUSLY and increases the longevity of the engine.
Peace...
My mods are below...
Coming soon!,
"Stage IV" Hahn Racecraft System,
PortFueler,
Hahn Aluminum Intake Manifold,
JE 8.9:1 Compression Pistons,
Eagle Connecting Rods,
Darton Sleeves,
Stage IV Clutch,
Will run daily @ 15psi and 25+ psi at the track!
Wednesday, September 28, 2005 7:59 AM
i read it somewhere maybe it was here that if u change the vavle springs on the ecotec then u can take it up to like 7500 rpms
MY 2003 SUNFIRE
~1QWKZ24
www.streetracing.org, 08/2001
